2 Replies Latest reply on Dec 2, 2009 1:08 AM by lathoudero
    No focus when using Custom Application Skin: Bug?
    lathoudero
      Hi all,
      Just wanted to be sure if I'm doing something wrong, or if it's a bug:
      When I create a Form within a VGroup, tabbing changes focus from TextInput to TextInput just fine.
      BUT when I create a custom skin for the application, everytime I press the 'Tab' button, the form loses it's focus from the FORM it's in, to the Main application!!
      This is the skin I'm using (ApplicationBGSkin):
           ADOBE SYSTEMS INCORPORATED
           Copyright 2008 Adobe Systems Incorporated
           All Rights Reserved.
           NOTICE: Adobe permits you to use, modify, and distribute this file
           in accordance with the terms of the license agreement accompanying it.
      <!--- The default skin class for the Spark Application component.
           @langversion 3.0
           @playerversion Flash 10
           @playerversion AIR 1.5
           @productversion Flex 4
      <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
              alpha.disabled="0.5">
          <fx:Metadata>
              <![CDATA[
           * A strongly typed property that references the component to which this skin is applied.
              [HostComponent("spark.components.Application")]
          </fx:Metadata>
          <s:states>
              <s:State name="normal"/>
              <s:State name="disabled"/>
              <s:State name="normalWithControlBar"/>
              <s:State name="disabledWithControlBar"/>
          </s:states>
          <!-- fill -->
               A rectangle with a solid color fill that forms the background of the application.
               The color of the fill is set to the Application's backgroundColor property.
          <s:Rect id="backgroundRect"
                  left="0"
                  right="0"
                  top="0"
                  bottom="0">
              <s:fill>
                  <s:SolidColor color="0xFFFFFF"/>
              </s:fill>
          </s:Rect>
               @copy spark.components.SkinnableContainer#contentGroup
          <s:Scroller top="0"
                      bottom="0"
                      width="580"
                      horizontalCenter="0"
                      horizontalScrollPolicy="off">
              <s:VGroup clipAndEnableScrolling="true"
                        width="100%"
                        height="100%">
                  <s:Graphic>
                      <s:BitmapImage source="@Embed(source='assets/images/header.png')"/>
                  </s:Graphic>
                  <s:Group id="contentGroup"
                           width="100%"
                           minWidth="0"
                           minHeight="0" hasFocusableChildren="true"/>
                  <s:BitmapImage source="@Embed(source='assets/images/footer.png')"/>
              </s:VGroup>
          </s:Scroller>
      </s:Skin>
      This is the Application:
                     xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="1024" minHeight="768"
                     skinClass="ApplicationBGSkin">
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <mx:Form left="10" top="10">
              <mx:FormHeading label="Heading"/>
              <mx:FormItem label="Label">
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
                  <s:TextInput/>
              </mx:FormItem>
          </mx:Form>
      </s:Application>
        • 1. Re: No focus when using Custom Application Skin: Bug?
          Flex harUI Adobe Employee
          Scroller might need hasFocusableChildren=true, I don't remember its current default value.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: No focus when using Custom Application Skin: Bug?
            lathoudero Level 1
            Indeed, this was the correct answer: The scroller in the skin needs[hasFocusableChildren=true]
                <s:Scroller top="0"
                            bottom="0"
                            width="580"
                            hasFocusableChildren="true">
                              width="100%"
                              height="100%">
                        <s:Graphic>
                        </s:Graphic>
                                 width="100%"
                                 minWidth="0"
                    </s:VGroup>
                </s:Scroller>
            Is there some logic when I should apply this? Like, which other components don't pass the focus to it's children?
            Or is using a scroller in an application-skin an unconventional way to create a fully scrollable interface?
            Thanks for the answer!
