1. Re: Button dimensions
Stan Jones Dec 1, 2009 8:52 AM (in response to Andy Bay)There have been some shifts if the size or par of the menu in photoshop is not correct. This is not the common issue for your problem, however, which is usually operator error.
Remember that the "button" size for purposes of overlap in EN is the smallest rectangular that contains all the elements of that button group. For example, I missed moving a button element I had copied the other day, and, after saving and moving back to Encore, see a big overlap alert that covered the whole menu.
I generally make my adjustments in PS, with the exception of simple moves of full button groups and text changes. I also start with templates for my version (CS3), to ensure that I am not introducing the slight oddities of incorrect par/pixel size.
I would go back to your first menu and redo the changes you made then. Make careful note of what you change, and if you get the overlap, try to sort out what you did.
2. Re: Button dimensions
Bill Hunt Dec 1, 2009 9:17 AM (in response to Andy Bay)Andy,
When there are size issues between PS and En, it often suggests that there is a mismatch between the size of the Menu (and its PAR) and the Project Preset in En.
Also, remember Stanley's words about a rectangle that encompasses all elements in a Button [OK, that is a paraphrase.] All elements MUST fit into a rectangle (or square), and even an overlap at a corner of that rectangle will not work.
With a perfect match in dimensions and PAR, you should not get any size change. Check those dimensions and the PAR carefully.
In PS, you can check your rectangle by making that Button active in the Layers Palette, and then hitting Ctrl+T (Free Transform Tool), and looking at the Bounding Box. That will show you the full rectangle. Unfortunately, you can only see one Button at a time with this method, but you should be able to pick up any overlap in PS. You can also place Guides for these Bounding Boxes, while they are visible. This will then allow you to see where the Bounding Boxes are, with these Guides.
Hope that this helps,
3. Re: Button dimensions
Andy Bay Dec 1, 2009 10:03 AM (in response to Bill Hunt)Thanks guys, I will try out your suggestions!
4. Re: Button dimensions
Bill Hunt Dec 1, 2009 2:56 PM (in response to Andy Bay)Good luck, and hope that you report 100% success.
If you have any questions, do not hesitate to stop back by.
