5 Replies Latest reply on Dec 1, 2009 2:49 PM by Tal770
    nested movieclip not showing on stage
    Tal770
      on frame 1
      for (j=0; j<20; j++) {
      duplicateMovieClip("letterCont", "Letter"+j, j);
      //this frame is executed only once
      on frame 2
      if (j<MsgLen) {
      // remove old clip in a loop sequence
        _root["Letter"+j]["let"+j].removeMovieClip();
        _root["Letter"+j].attachMovie("let"+ord(substring(Message, j, 1)),"let"+ j,j+200); // as was suggested to place it in diffrent depth
      } else {
      //  _root["Letter"+j]["let"+j]._visible = false;
      on frame 3
      //updating the clips position and size
      for (j=0; j<MsgLen; j++) {
      if (k<9) {
        if (pos-j>=0 && pos-j<9) {
         _root["Letter"+j]["let"+j]._width = Wchar[pos-j];
         _root["Letter"+j]["let"+j]._height = Hchar[pos-j];
         _root["Letter"+j]["let"+j]._x = Xchar[pos-j];
         _root["Letter"+j]["let"+j]._y = Ychar[pos-j];
         _root["Letter"+j]["let"+j]._visible = true;
        trace("for j= " + j + "  --  " + _root["Letter"+j]["let"+j]._visible + "  -  " + _root["Letter"+j]["let"+j]._alpha) // the results is allways true  -  100
        } else {
      //  _root["Letter"+j]["let"+j]._visible = false;   For test I marked them as remark
        k += 1;
      } else {
      //  _root["Letter"+j]["let"+j]._visible = false;For test I marked them as remark
      frame 3 is looped until all 20 are shown and then it send back to frame 2
      The checking the data given in frame 3 is correct
      What my couse it not to show?
      is there a way to debug the clip it self the?
      _x _y _width _height on the debugger has correct values for all clips as expected but the clip is not on the stage why?
