2 Replies Latest reply on Dec 1, 2009 4:24 PM by jerryhamby
    Using SerialElement with static vars
    jerryhamby
      ========== The Goal ====================
      To get access to the MediaPlayer's element properties and methods, such as (numChildren, getChildAt, etc…)
      My goal is to build a Image Viewer (using left and right arrows) that uses SerialElement as the source of the images.
      Please note the class where all this lives, is a Singelton-type class using static vars.
      ========== Code Snippet ====================
      (using Sprint 7 on CS4)
      public static var pPlayer:MediaPlayer;
      public static var pImageSerialElement:SerialElement;
      pPlayer = new MediaPlayer();
      pImageSerialElement = new SerialElement();
      pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image1.jpg"))));
      pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image2.png"))));
      pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image3.png"))));
      pPlayer.element=pImageSerialElement;
      trace("pImageSerialElement = " + pImageSerialElement);     //// [object SerialElement]
      trace("pImageSerialElement.numChildren = "+pImageSerialElement.numChildren);  //// 3
      trace("pPlayer.element = " + pPlayer.element);       //// [object SerialElement]
      trace("pPlayer.element.numChildren = " + pPlayer.element.numChildren);    ////// this is where I get the error
      ========== The Error ====================
      1119: Access of possibly undefined property numChildren through a reference with static type org.osmf.media:MediaElement.
      Even though I can see the data in Debug mode, I can't get pass the error message.
      What am I doing wrong?
        • 1. Re: Using SerialElement with static vars
          bringrags Level 4
          I assume by "error" you mean a compile error:  you're trying to access numChildren through a MediaElement variable rather than a SerialElement variable, which won't work.  You could work around this by casting to SerialElement:
          trace("pPlayer.element.numChildren = " + SerialElement(pPlayer.element).numChildren);
          Can I ask why you need to access numChildren?  The point of SerialElement is you set it up, then interact with it as if it were a MediaElement.
          • 2. Re: Using SerialElement with static vars
            jerryhamby Level 1
            Thanks for reply:
            I wanted to create a Image viewer that could be manipulated using a controller (you know, next and previous buttons).
            I wanted to see if I could use the SerialElement as the data source, instead of building an array. The numChildren would give
            me the count of the SerialElement.
            FYI, I wasn't interested in using TemporalProxyElement cause I'm not building a slideshow at the moment.
            I have mostly figured out things in the code below:
               public static function mPlayImageSeq(vImageToPlay:Number):void {
            pPlayer.element = null;
            pMediaSprite = new Sprite();
            AppMaster.pMediaPlaceHolder.addChild(pMediaSprite);
            pPlayer.addEventListener(LoadableStateChangeEvent.LOADABLE_STATE_CHANGE, mImageLoadableStateChange );
            pPlayer.addEventListener(MediaPlayerCapabilityChangeEvent.VIEWABLE_CHANGE, mViewable );
            pMediaSprite.addEventListener(MouseEvent.CLICK , mImageClicked );
            if (vImageToPlay > 998){
            }else{
               pPlayer.element=pImageSerialElement.getChildAt(vImageToPlay);
              trace("pPlayer.element = "+pPlayer.element);
              // trace("pPlayer.element.numChildren = "+pPlayer.element.numChildren);
              trace("pImageSerialElement.getChildAt(0) = "+pImageSerialElement.getChildAt(0))
