0 Replies Latest reply on Dec 1, 2009 1:09 PM by Christian Pillsbury
    imports of Vector removed in FlashBuilder 4
    Christian Pillsbury
      I'm noticing that in FB4, any Vector import is automatically removed by code cleanup and the SWFs/SWCs still build fine in that environment.  However, in either FB3, Eclipse w/Flex plugin, or (at least older versions of) ant builds, this same code will get a compiler error.  Can someone explain why this is, and what I should look for in the "problematic" environments to make them capable of also compiling w/out the import, if this is at all possible?
