0 Replies Latest reply on Dec 1, 2009 1:36 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12334: Fix http://bugs.adobe.com/jira/browse/ SDK-24217 Layout properties not being applied the same way during component creation vs being set after component is created
    Evtim Georgiev (Adobe) Level 2
      Revision: 12334
      Revision: 12334
      Author:   egeorgie@adobe.com
      Date:     2009-12-01 13:36:03 -0800 (Tue, 01 Dec 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-24217 Layout properties not being applied the same way during component creation vs being set after component is created
      Problem: GroupBase transfers clipAndEnableScrolling value from the old layout to the new layout unconditionally.
      Fix: Transfer the value only if it was explicitly set on the GroupBase itself.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24217
      Reviewer: Ryan, Hans
      Tests run: checkintests, mustella/tests/gumbo/core
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
