0 Replies Latest reply on Dec 1, 2009 2:28 PM by CoreyRLucier
    [svn:fx-trunk] 12339: Reducing some of the event dispatching noise in the SDK.
    CoreyRLucier Adobe Employee
      Revision: 12339
      Revision: 12339
      Author:   clucier@adobe.com
      Date:     2009-12-01 14:28:31 -0800 (Tue, 01 Dec 2009)
      Log Message:
      Reducing some of the event dispatching noise in the SDK.  Seeing pretty good results in our runtime performance tests and startup times... 5%-15% improvement over all.  This is about all we'll be able to commit to for Flex 4.0.  Added hasEventListener test before dispatching more of our lifecycle events.  Modified compiler binding code-gen to do the same.  Documented all public facing events where applicable to denote that they are no longer capturable by default.
      QE notes: No
      Doc notes: No
      Bugs: SDK-24249
      Reviewer: Alex
      Tests run: Mustella, Checkin
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24249
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/FlexEvent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientEntry.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColor.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColorStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/LayoutManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/systemClasses/ChildManager.a s
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/State.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderContainerSkin.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableProperty.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
