2 Replies Latest reply on Oct 22, 2013 11:14 AM by Patrick Schulz
    InDesignServer Service not starting on Windows Server 2003 (32bit & 64 bit)
    Eliot Harper
      Note: this issue is different from this thread on a similar issue.
      This problem has plagued me for weeks and I finally give up. InDesign Server installs successfully and the InDesignServerService starts, but the server does not run. I can only run the server from the command line. I've followed these installation instructions but run into the following problems:
      1. installing by the command line: InDesignServerService /install fails and produces the following error log:
      Installing service InDesignServerService...
      Creating EventLog source InDesignServerService in log Application...
      Rolling back assembly 'E:\Program Files\Adobe InDesign CS4 Server\InDesignServerService.exe'.
      Affected parameters are:
         logtoconsole =
         assemblypath = E:\Program Files\Adobe InDesign CS4 Server\InDesignServerService.exe
         logfile = E:\Program Files\Adobe InDesign CS4 Server\InDesignServerService.InstallLog
      Restoring event log to previous state for source InDesignServerService.
      2. I cannot install or load the snap-in to MMC. When I try to install regsvr32 InDesignServerMMC.dll it cannot be found (as it's not in the InDesign Server directory). However InDesignServerMMC64.dll is in there and I was able to load the snap-in using regsvr32 InDesignServerMMC.dll, but the server still only runs when being started from the command line.
      As I mentioned, InDesign Server runs fine when I have an active command line window open and run InDesignServer, but the moment I close the command line window, the server shuts down. Any ideas?
