2 Replies Latest reply on Jun 22, 2016 8:45 AM by arliner66148179
    Unable to resize an object with the select tool (black arrow)?
    JOEL NEELEN Level 1
      If drawn an object I'm suddenly unable to resize it by dragging one of its corners with the select tool.
      The object isn't locked. The layer which the object is upon isn't locked. I can only move the object around.
      If I use the transform tool I can also resize it, but not with the black arrow by dragging its corners.
      What could have caused this problem?
      I've read in this form to hold down Command-Option-Shift while relaunching Illustrator. Does that fix my problem?
