0 Replies Latest reply on Dec 2, 2009 5:30 AM by Carol L. Frampton
    [svn:fx-trunk] 12362: Revert the part of svn 12322 that added support for custom context menus to TextArea , TextInput and RichEditableText.
    Carol L. Frampton Level 2
      Revision: 12362
      Revision: 12362
      Author:   cframpto@adobe.com
      Date:     2009-12-02 05:30:12 -0800 (Wed, 02 Dec 2009)
      Log Message:
      Revert the part of svn 12322 that added support for custom context menus to TextArea, TextInput and RichEditableText.  This needs to be reworked so that it builds and works correctly for AIR apps as well.
      Apparently you can't override the contextMenu setter/getter because they use a ContextMenu on Flash and a NativeMenu on AIR so the signatures will only match one environment depending on which menu class you use.
      Reopened SDK-23926.
      QE notes:
      Doc notes:
      Bugs: SDK-23926
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23926
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableTex tBase.as
