0 Replies Latest reply on Dec 2, 2009 8:37 AM by deepa subramaniam (adobe)
    [svn:fx-trunk] 12368: Rename spark.components.supportClasses. Slider to spark.components.supportClasses.SliderBase as well as spark. components.supportClasses.ScrollBar to spark.components.supportClasses. ScrollBarBase.
    deepa subramaniam (adobe) Level 2
      Revision: 12368
      Revision: 12368
      Author:   dsubrama@adobe.com
      Date:     2009-12-02 08:37:28 -0800 (Wed, 02 Dec 2009)
      Log Message:
      Rename spark.components.supportClasses.Slider to spark.components.supportClasses.SliderBase as well as spark.components.supportClasses.ScrollBar to spark.components.supportClasses.ScrollBarBase. This means the spark manifest entries have also changed (for CSS styling purposes, not for use as mxml tags) (Slider -> SliderBase, ScrollBar -> ScrollBarBase).
      Change is PARB approved.
      QE notes: Please check-in the updated tests
      Doc notes: ASDoc has been updated. If any updates need to happen in livedocs, please do so.
      Bugs: SDK-24401
      Reviewer: Ryan/Jason
      Tests run: Jacob ran a cyclone
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24401
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/components/CircularScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ScrollerLayo ut.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/SliderBaseAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ScrollBarBas e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SliderBase.a s
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/SliderAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ScrollBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Slider.as
