0 Replies Latest reply on Dec 2, 2009 8:51 AM by mraccess1977
    [svn:fx-3.x] 12371: The main AccImpl was updated to handle accessible naming conventions differently than before .
    mraccess1977
      Revision: 12371
      Revision: 12371
      Author:   jon.avila@ssbbartgroup.com
      Date:     2009-12-02 08:51:12 -0800 (Wed, 02 Dec 2009)
      Log Message:
      The main AccImpl was updated to handle accessible naming conventions differently than before.  This change was made to make the 3.x branch consistent with the trunk changes.  The updated methods allows the accessibilityName property to overwrite the logic that was previously used to build the accessible name for components that were inside of forms.  This method also provides a method to allow developers to specificy that no form heading or form item label should be included in the accessibilityName for the form field by using a space.
      QE notes: none
      Doc notes: none
      Bugs: n/a
      Reviewer: Gordon
      Tests run: checkintests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/branches/3.x/frameworks/projects/framework/src/mx/accessibility/AccImpl.as
