5 Replies Latest reply on Dec 2, 2009 6:42 PM by Jeff_Coatsworth
    How 2 copy hhc from proj to dup proj
    gsmichaels Level 1
      I successfully created a duplicate project, but not the dup hhc. Tried copying the hhc from the source to the dup project and renaming it. This seemed to work. However, the next day, after reopening the dup project and getting the latest files, the desired hhc had become a 1 KB file. The orig. 47 KB  file had been, I guess, overwritten. I might note that between closing the project and reopening it the following day, I had updated RH with the 8.02  release.
      I have since attempted to repeat the steps that led to my initial success with the copied hhc. Thus far, I've failed. RH won't recognize the imported hhc. Instead, it seems to create dup version of its own at 1 KB.  That version is listed in the C: drive project file immediately below the file I imported (sized at 47 KB). Deleting the 1 KB version doesn't seem to make a difference.
      Your suggestions would be welcome.
        • 1. Re: How 2 copy hhc from proj to dup proj
          Hi there
          The crystal ball is in the shop. Sorry. What version of RoboHelp are you using? What flavor? How did you "duplicate" your project?
          There are many options we might suggest. However, with the dearth of information, it's rather difficult to offer a meaningful suggestion.
          Cheers... Rick
          Helpful and Handy Links
          RoboHelp Wish Form/Bug Reporting Form
          Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
          Adobe Certified RoboHelp HTML Training
          SorcerStone Blog
          RoboHelp eBooks
          • 2. Re: How 2 copy hhc from proj to dup proj
            gsmichaels Level 1
            Apologies! You're absolutely correct. Well, I'm in RH 8 (though I
            think that I did reference the use of the 8.02 update).
            How did I create the dup project. Laboriously. I created a new project, then ended up copying the files from the source to the new project. I'm not sure where I went wrong, but I ended up having to delete copies (of the copies), more than once... one by one.
            I generated the orig. TOC in the dup project by assigning a new name via the TOC Auto-Create function. I chose to turn bookmarks into TOC listings before I realized that this was utterly counter productive for my purposes. I ended deleting the whole thing by creating another TOC and making it the default TOC. Actually, I've done this multiple times as I've attempted to refine my technique.
            In short, I've made every mistake I could think of and some I couldn't have predicted, as well.
            Next question?
            • 3. Re: How 2 copy hhc from proj to dup proj
              Hi there
              Sorry if I missed your reference to the update.
              Usually copying a project is simple. Takes but a minute or two. You just locate the folder with the project, then copy all the files and folders inside and paste into a new location. Simple as that. Once you do this, you then typically Rename the project.
              As for the TOC, you have some options. From the TOC pod, click the New TOC icon.
              It may look like this and you will need to click the arrow to see it.
              Choose New and you are given the option of copying a TOC.
              Cheers... Rick
              SorcerStone Blog
              RoboHelp eBooks
              • 4. Re: How 2 copy hhc from proj to dup proj
                gsmichaels Level 1
                Thank you, sir. That is the correct answer. You win the BIG PRIZE!
                Here's why I didn't figure it out. Once within the New Table of Contents dialog, populating the Name field - even when the Copy existing Table of Contents check box is flagged - does not prompt RH to visually activate the gray field or adjacent button at the bottom of the dialog. Those fields appeared to be inactive (to me). Thus, I had no idea that left-clicking the button would actually open a Browse Table of Contents Files display. Only after the user selects this option and cancels out of it, returning to the dialog, is there any visual indication that the button is active... in the form of a darkened outline.
                Please bring this to the attention of whomever establishes / double-checks functionality standards.
                It would also be nice if the user had the option, within the TOC, of selecting a given listing and then selecting an icon that would move the listing to the very top/bottom of the TOC.
                Lastly, it couldn't hurt to display a rollover somewhere in the TOC display that informs the user that entries can be dragged into the TOC from the Topic List display. This is much quicker than trying to drag an existing TOC listing up or down the display when dozens of listings are shown.
                Many, many thanks for your assistance.
                • 5. Re: How 2 copy hhc from proj to dup proj
                  Jeff_Coatsworth Adobe Community Professional & MVP
                  Don't bother kvetching here in the forums about something like that - go the wish list link (found in Rick's signature line) & tell Adobe directly - the more people ask for something, the more likely it might get some programming attention. Kvetching to the right people makes the software world go round!
