7 Replies Latest reply on Dec 2, 2009 3:53 PM by kglad
    Bring XML into flash using a variable
    BrianStapleton
      Hi everyone.
      I have a movieclip (jobImage) which I'm loading an image (Image1, a subnode of Job1) into using XML. But I want to be able to click on any one of a series of buttons which will have that image replaced by a new image (eg. Button2 will load Image2, another subnode of Job1, Button3 will load Image3, etc.).
      So I have the selected button pass a number back to a variable called "_root.imageTarget". If Button2 was pressed, this would happen:
      _root.imageTarget = "2";
      This variable is then combined with the word "Image" to form a new variable (newImage)
      newImage = "Image" + _root.imageTarget;
      And that variable is used to load the correct node
      jobImage.loadMovie("Images/" + work_arr[Job1].newImage);
      Except it doesn't work. Any ideas why? When I write the actual name of the node, the script us successful:
      jobImage.loadMovie("Images/" + work_arr[Job1].Image2);
      Is it not possible to use a variable to target the correct node?
      Thanks for your time!
      Brian
