2 Replies Latest reply on Dec 3, 2009 9:47 AM by BoydMills
    changing the background image of a canvas at runtime
    BoydMills
      Bindable]protected var bgImage:Image;
      private
      private
      function GetConfigurationResult( event:WsVCIGetConfigurationDataResultEvent):void
      var simage:String = event.result.Image;
      var decoded:ByteArray;
      decoder.decode( simage );
      decoded = decoder.toByteArray( );
      bgImage.data = decoded;
      setStyle(
      "backgroundImage", "assets/images/marshes2.jpg" );
      The code above is the result event from a call to a web service to get the contents of an image file from and SQL database.
      Works ok up to bgImage.data = decoded;
      But using "setStyle" has no parameter for passing the bytearray data block of the image.
      The above code, calling [ ("backgroundImage", "assets/images/marshes2.jpg" ] does something, but not what I want.
      The web service is called from the canvas [ initialize="init();"] function.
      When I set canvas feature [ backgroundImage="{bgImage}" ] it resolves, but I get some error trap from some low level image handling module.
      How do I resolve a background  image during load at runtime?
        • 1. Re: changing the background image of a canvas at runtime
          BoydMills Level 1
          I think my original post was a little short on detail.
          The object bgImage:Image is populated by extracting the contents of an image file stored in an SQL database extracted by way of a web service.
          That all works, I get the bytearray of the image into my variable.
          I do this in other places where I am displaying an Image on top of (within ?) a canvas.
          My issue here is to use this bytearray that is the data section of an image file as the background for the canvas itself.
          Every example I have found requires the canvas background be loaded from an explicity file or be changed by refereing to a different explicity file.  What I need here is to load the background after making the round trip to a web service.
          Any words of wisdom?
          Boyd
          • 2. Re: changing the background image of a canvas at runtime
            BoydMills Level 1
            Since setStyle takes a string and an object for inputs, one would expect that the following would work
            private function GetConfigurationResult( event:WsVCIGetConfigurationDataResultEvent):void
            {// retrieve the 64base encoded image from the web service by ResultEvent
            var
            bgImage:Image =new Image();
            var
            decoder:Base64Decoder = new Base64Decoder();
            setStyle(
            "backgroundImage", bgImage );
            But this generates the following error:
            Error: Unable to load 'Image52'.
            at mx.skins::RectangularBorder/updateDisplayList()[C:\autobuild\3.2.0\frameworks\projects\fr amework\src\mx\skins\RectangularBorder.as:237]
            at mx.skins.halo::HaloBorder/updateDisplayList()[C:\autobuild\3.2.0\frameworks\projects\fram ework\src\mx\skins\halo\HaloBorder.as:222]
            at mx.skins::ProgrammaticSkin/validateDisplayList()[C:\autobuild\3.2.0\frameworks\projects\f ramework\src\mx\skins\ProgrammaticSkin.as:421]
            at mx.managers::LayoutManager/validateDisplayList()[C:\autobuild\3.2.0\frameworks\projects\f ramework\src\mx\managers\LayoutManager.as:622]
            at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.2.0\frameworks\projects \framework\src\mx\managers\LayoutManager.as:677]
            at Function/http://adobe.com/AS3/2006/builtin::apply()
            at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.2.0\frameworks\projects\framew ork\src\mx\core\UIComponent.as:8628]
            at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.2.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:8568]
            But passing a filename to setStyle works!!!!
            But I need the image to come from a database!!!!!!
            Help!
