4 Replies Latest reply on Dec 3, 2009 8:10 AM by HDDesigns
    Design ecover?
    HDDesigns
      Where can I find step by step instructions to design an ecover using Fireworks?
      I've done extensive searches in Google but only find Photoshop Tutorials.
        • 1. Re: Design ecover?
          Michel Bozgounov Level 2
          If you mean, "use graphic tools to create a graphic design with Fireworks" this should be not much different from Photoshop. I don't know what's an e-cover (ecover?) though, so I can't help you in this issue specifically.
          As to tutorials, there are many tutorials about Fireworks and how you can best use its tools, so I hope you'll find what you need...
          • 2. Re: Design ecover?
            HDDesigns Level 1
            Thanks for your feedback..I was referring to an ebook cover.
            • 3. Re: Design ecover?
              ebook, like.... PDF electronic book?
              You can use Fireworks for that. Fireworks is a screen graphic design application, so for an e-book, it should be easy and appropriate to be used.
              If you plan to create design for print, then Fireworks is not your tool of choice -- better use Illustrator in this case (Illustrator and Photoshop support CMYK color formats, while Fireworks supports only RGB/RGBa, which means, this is not a tool to be used for print.)
              If the ebook will be used on screen only, or mostly on screen, then Fireworks can do the job easily.
              Simply create a new PNG document in Fireworks, with the right dimensions, and start creating the design in it. There are a lot of tutorials which deal with how to use Fireworks for all kinds of basic and more advanced design tasks!
              Hope this helps?
              • 4. Re: Design ecover?
                HDDesigns Level 1
                Thanks...see the attached file for my first attempt
                based on a simple Photoshop tutorial however I'm
                not entirely happy with it because the inside of the
                book is not prefect and I couldn't figure out how to make
                shadows (apart from drop shadow).
                I'm still looking for a step by step tutorial to
                design an ecover graphic using FW.
