2 Replies Latest reply on Dec 2, 2009 4:14 PM by Jim_Simon
    Error compiling movie.  I/O Error.
    putsiküllkrdimunn
      Hello.
      Im not sure if i should have posted in the hardware section.
      I have done some reaserch on this problem but haven't really got the solution.
      It doesnt matter what format i export it always gives me this error. With h264 and some else, its a bit different too.
      - Source File: C:\Users\SEMPER~1\AppData\Local\Temp\Untitled_1.prproj
      - Output File: C:\Users\Kristjan\Desktop\Sequence 01.mp4
      - Preset Used: YouTube KW
      - Video: NTSC, 480x360, 30 [fps], Progressive
      - Audio: AAC, 64 [kbps], 48 kHz, Stereo
      - Bitrate: VBR, 1 Pass, Target 1,55, Max 2,29 [Mbps]
      - Encoding Time: 00:00:00
      3.12.2009 0:53:45 : Encoding Failed
      Cannot open "C:\Users\Kristjan\Desktop\Sequence 01.mp4" file for writing. Please check the output filename and file permissions (if it already exists) and then try again.
      - Source File: C:\Users\SEMPER~1\AppData\Local\Temp\Untitled_2.prproj
      - Output File: C:\Users\Kristjan\Desktop\Sequence 01.avi
      - Preset Used: NTSC DV
      - Video: 720x480, 29.97 [fps], Lower, Quality 100
      - Audio: 48000 Hz, Stereo, 16 bit
      - Bitrate:
      3.12.2009 0:54:47 : Encoding Failed
      I/O Error.
      - Source File: C:\Users\SEMPER~1\AppData\Local\Temp\Untitled_3.prproj
      - Bitrate:
      3.12.2009 0:58:04 : Encoding Failed
      I/O Error.
      - Source File: C:\Users\SEMPER~1\AppData\Local\Temp\Untitled_4.prproj
      - Preset Used: Custom
      - Video: 720x480, 25 [fps], Progressive, Quality 100
      - Bitrate:
      3.12.2009 1:08:37 : Encoding Failed
      I/O Error.
      - Source File: C:\Users\SEMPER~1\AppData\Local\Temp\Chemistry, Copper_6.prproj
      - Output File: C:\Users\Kristjan\Desktop\Youtube.avi
      - Bitrate:
      - Encoding Time: 00:00:01
      3.12.2009 1:28:42 : Encoding Failed
      There are alot of errors about my hard drive in the event viewer aswell. I have 2 hard drives.
      The device, \Device\Harddisk1\DR1, has a bad block.
      The driver detected a controller error on \Device\Harddisk2\DR2.
      even my cd rom has a bad block, The device, \Device\CdRom0, has a bad block.
      I defrag my drives regulary.
      My PC ,I use the "system information" option that win 7 has :
      OS Name Microsoft Windows 7 Ultimate
      Version 6.1.7600 Build 7600
      Other OS Description Not Available
      OS Manufacturer Microsoft Corporation
      System Name SEMPERFI-PC
      System Manufacturer System manufacturer
      System Model System Product Name
      System Type x64-based PC
      Processor Intel(R) Core(TM)2 Duo CPU     E8400  @ 3.00GHz, 2997 Mhz, 2 Core(s), 2 Logical Processor(s)
      BIOS Version/Date American Megatrends Inc. 0503, 14.07.2009
      SMBIOS Version 2.5
      Windows Directory C:\Windows
      System Directory C:\Windows\system32
      Boot Device \Device\HarddiskVolume2
      Locale Eesti
      Hardware Abstraction Layer Version = "6.1.7600.16385"
      User Name SemperFi-PC\Semper Fi
      Time Zone FLE Standard Time
      Installed Physical Memory (RAM) 4,00 GB
      Total Physical Memory 4,00 GB
      Available Physical Memory 2,10 GB
      Total Virtual Memory 8,00 GB
      Available Virtual Memory 5,47 GB
      Page File Space 4,00 GB
      Page File C:\pagefile.sys
      I/O:
      0x00000000-0x0000000F Direct memory access controller OK
      0x00000000-0x0000000F PCI bus OK
      0x00000010-0x0000001F Motherboard resources OK
      0x00000020-0x00000021 Programmable interrupt controller OK
      0x00000022-0x0000003F Motherboard resources OK
      0x00000040-0x00000043 System timer OK
      0x00000044-0x0000004D Motherboard resources OK
      0x00000050-0x0000005F Motherboard resources OK
      0x00000061-0x00000061 System speaker OK
      0x00000062-0x00000063 Motherboard resources OK
      0x00000065-0x0000006F Motherboard resources OK
      0x00000070-0x00000071 System CMOS/real time clock OK
      0x00000072-0x0000007F Motherboard resources OK
      0x00000080-0x00000080 Motherboard resources OK
      0x00000081-0x00000083 Direct memory access controller OK
      0x00000084-0x00000086 Motherboard resources OK
      0x00000087-0x00000087 Direct memory access controller OK
      0x00000088-0x00000088 Motherboard resources OK
      0x00000089-0x0000008B Direct memory access controller OK
      0x0000008C-0x0000008E Motherboard resources OK
      0x0000008F-0x0000008F Direct memory access controller OK
      0x00000090-0x0000009F Motherboard resources OK
      0x000000A0-0x000000A1 Programmable interrupt controller OK
      0x000000A2-0x000000BF Motherboard resources OK
      0x000000C0-0x000000DF Direct memory access controller OK
      0x000000E0-0x000000EF Motherboard resources OK
      0x000000F0-0x000000FF Numeric data processor OK
      0x00000290-0x00000297 Motherboard resources OK
      0x000003B0-0x000003BB Intel(R) X38/X48 Express Chipset PCI Express Root Port - 29E1 OK
      0x000003B0-0x000003BB ATI Radeon HD 3850 OK
      0x000003C0-0x000003DF Intel(R) X38/X48 Express Chipset PCI Express Root Port - 29E1 OK
      0x000003C0-0x000003DF ATI Radeon HD 3850 OK
      0x000003F8-0x000003FF Communications Port (COM1) OK
      0x00000400-0x0000041F Intel(R) ICH9 Family SMBus Controller - 2930 OK
      0x00000480-0x000004BF Motherboard resources OK
      0x000004D0-0x000004D1 Motherboard resources OK
      0x00000800-0x0000087F Motherboard resources OK
      0x00000D00-0x0000FFFF PCI bus OK
      0x00009400-0x0000940F Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x00009480-0x0000948F Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x00009800-0x00009803 Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x00009880-0x00009887 Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x00009C00-0x00009C03 Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x0000A000-0x0000A007 Intel(R) ICH9R/DO/DH 4 port Serial ATA Storage Controller 1 - 2920 OK
      0x0000A400-0x0000A40F Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000A480-0x0000A48F Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000A800-0x0000A803 Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000A880-0x0000A887 Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000AC00-0x0000AC03 Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000B000-0x0000B007 Intel(R) ICH9 Family 2 port Serial ATA Storage Controller 2 - 2926 OK
      0x0000B080-0x0000B09F Intel(R) ICH9 Family USB Universal Host Controller - 2934 OK
      0x0000B400-0x0000B41F Intel(R) ICH9 Family USB Universal Host Controller - 2935 OK
      0x0000B480-0x0000B49F Intel(R) ICH9 Family USB Universal Host Controller - 2936 OK
      0x0000B800-0x0000B81F Intel(R) ICH9 Family USB Universal Host Controller - 2937 OK
      0x0000B880-0x0000B89F Intel(R) ICH9 Family USB Universal Host Controller - 2938 OK
      0x0000BC00-0x0000BC1F Intel(R) ICH9 Family USB Universal Host Controller - 2939 OK
      0x0000C000-0x0000CFFF Intel(R) X38/X48 Express Chipset PCI Express Root Port - 29E1 OK
      0x0000C000-0x0000CFFF ATI Radeon HD 3850 OK
      0x0000D000-0x0000DFFF Intel(R) ICH9 Family PCI Express Root Port 6 - 294A OK
      0x0000D800-0x0000D8FF Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller OK
      0x0000E000-0x0000EFFF Intel(R) ICH9 Family PCI Express Root Port 5 - 2948 OK
      0x0000E400-0x0000E40F Standard Dual Channel PCI IDE Controller OK
      0x0000E480-0x0000E483 Standard Dual Channel PCI IDE Controller OK
      0x0000E800-0x0000E807 Standard Dual Channel PCI IDE Controller OK
      0x0000E880-0x0000E883 Standard Dual Channel PCI IDE Controller OK
      0x0000EC00-0x0000EC07 Standard Dual Channel PCI IDE Controller OK
      0x0000FFE0-0x0000FFEF AS0MMTY9 IDE Controller OK
      Drives:
      Drive C:
      Description Local Fixed Disk
      Compressed No
      File System NTFS
      Size 149,05 GB (160 040 443 904 bytes)
      Free Space 57,80 GB (62 065 405 952 bytes)
      Volume Name
      Volume Serial Number 44C64C64
      Drive D:
      Compressed No
      File System NTFS
      Size 149,05 GB (160 038 907 904 bytes)
      Free Space 53,30 GB (57 233 891 328 bytes)
      Volume Name Windows
      Volume Serial Number 728D93DE
      Drive E:
      Description CD-ROM Disc
      Drive G:
      Disks:
      Description Disk drive
      Manufacturer (Standard disk drives)
      Model SAMSUNG HD160JJ ATA Device
      Bytes/Sector 512
      Media Loaded Yes
      Media Type Fixed hard disk
      Partitions 1
      SCSI Bus 1
      SCSI Logical Unit 0
      SCSI Port 5
      SCSI Target ID 0
      Sectors/Track 63
      Size 149,05 GB (160 039 272 960 bytes)
      Total Cylinders 19 457
      Total Sectors 312 576 705
      Total Tracks 4 961 535
      Tracks/Cylinder 255
      Partition Disk #1, Partition #0
      Partition Size 149,05 GB (160 040 448 000 bytes)
      Partition Starting Offset 32 256 bytes
      Model WDC WD1600BB-00GUC0 ATA Device
      Bytes/Sector 512
      Media Loaded Yes
      Partitions 1
      SCSI Bus 0
      SCSI Logical Unit 0
      SCSI Port 0
      SCSI Target ID 0
      Sectors/Track 63
      Tracks/Cylinder 255
      Partition Disk #0, Partition #0
      Partition Size 149,05 GB (160 038 912 000 bytes)
      Partition Starting Offset 1 048 576 bytes
      Multimedia shows me these codecs:
      video:
      c:\windows\system32\iyuv_32.dll Microsoft Corporation OK C:\Windows\system32\IYUV_32.DLL 6.1.7600.16385 52,50 KB (53 760 bytes) 14.07.2009 3:06
      c:\windows\system32\msrle32.dll Microsoft Corporation OK C:\Windows\system32\MSRLE32.DLL 6.1.7600.16385 15,50 KB (15 872 bytes) 14.07.2009 3:18
      c:\windows\system32\msvidc32.dll Microsoft Corporation OK C:\Windows\system32\MSVIDC32.DLL 6.1.7600.16385 37,50 KB (38 400 bytes) 14.07.2009 3:18
      c:\windows\system32\msyuv.dll Microsoft Corporation OK C:\Windows\system32\MSYUV.DLL 6.1.7600.16385 24,00 KB (24 576 bytes) 14.07.2009 3:06
      c:\windows\system32\tsbyuv.dll Microsoft Corporation OK C:\Windows\system32\TSBYUV.DLL 6.1.7600.16385 14,00 KB (14 336 bytes) 14.07.2009 3:06
      c:\windows\system32\xfcode~1.dll Not Available Xfire video codec [XFR1] OK C:\Windows\system32\XFCODEC64.DLL 1.0.0.40405 26,89 KB (27 536 bytes) 30.11.2009 21:33
      audio:
      c:\windows\system32\imaadp32.acm Microsoft Corporation OK C:\Windows\system32\IMAADP32.ACM 6.1.7600.16385 21,50 KB (22 016 bytes) 14.07.2009 3:18
      c:\windows\system32\l3codeca.acm Fraunhofer Institut Integrierte Schaltungen IIS Fraunhofer IIS MPEG Layer-3 Codec OK C:\Windows\system32\L3CODECA.ACM 1.9.0.401 79,50 KB (81 408 bytes) 14.07.2009 3:22
      c:\windows\system32\msadp32.acm Microsoft Corporation OK C:\Windows\system32\MSADP32.ACM 6.1.7600.16385 23,50 KB (24 064 bytes) 14.07.2009 3:18
      c:\windows\system32\msg711.acm Microsoft Corporation OK C:\Windows\system32\MSG711.ACM 6.1.7600.16385 14,50 KB (14 848 bytes) 14.07.2009 3:18
      c:\windows\system32\msgsm32.acm Microsoft Corporation OK C:\Windows\system32\MSGSM32.ACM 6.1.7600.16385 28,50 KB (29 184 bytes) 14.07.2009 3:18
      I downloaded and installed the Win7 codecs by Shark. Because...there are any other codecs available for win 7 ?
      Tell me if need any more info..which u probably do.
      If there are any better forums for this kind of problem then please tell me.
      I hope we can fix this prooblem.
      I think i haven't said my motherboard. Its P5E3 PRO. It has EPU engine and it turns off the hard drive when its idle...Premiere pro and all the sytem files are installed on my C drive which is like the main drive. On D drive i keep my music, downloads and stuff. I think it can turn of both drives then idle, but mostly it turns off D drive, I think. I have a new motherboard and i haven't got the hang of it how it shuts them down.
      But i think this really isnt a problem.
      Thanks in advance.
