9 Replies Latest reply on Dec 7, 2009 4:00 PM by cyber0897
    cannot access a property or method of a null object reference
    cyber0897 Level 1
      hey guys... just like the title suggests...
      i get that error on the trouble.dataProvider = resultData.menu.apx32.troubleShooting.item; line
      and as you can see the line right above it has the exact same code... and that seems to work just fine...
      any help is appretiated!!!
      this is the code i have
      mxml file:
                  <mx:VBox label="USER OPTIONS" width="100%" height="100%">
                      <s:List id="userOptions" width="100%" height="100%" itemRenderer="modules.apx32.myComponents.listRenderer"
                              borderAlpha="0">
                      </s:List>
                  </mx:VBox>
                  <mx:VBox label="TROUBLESHOOTING">
                      <s:List id="trouble" width="100%" height="100%" itemRenderer="modules.apx32.myComponents.listRenderer"
                              borderAlpha="0">
                      </s:List>
                  </mx:VBox>
      actionscript file:
          private function myXml_resultHandeler(event:ResultEvent):void{
              var resultData:Object = event.result;
              userOptions.dataProvider = resultData.menu.apx32.userOptions.item;
        • 2. Re: cannot access a property or method of a null object reference
          mewk Level 3
          uhm. are you sure??
          the dataProvider for userOptions is resultData.menu.apx32.userOptions.item
          and for trouble it's resultData.menu.apx32.troubleShooting.item
          - e
          • 3. Re: cannot access a property or method of a null object reference
            cyber0897 Level 1
            what i ment to say was its relatively similar... the code i have in there should be getting two different values... but using the exact same method...
            my xml contains both of the tags... and when i hit the debug button, it it shows me that the array contains both troubleshooting, and userOptions...
            the xml is as follows
            <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
            <menu>
               <apx32>
                      <userOptions>
                        <item label="Adjust Volume">
                               <images>
                                  <url>images/APX32-adjustingVolume_01.png</url>
                               </images>
                               <video>true</video>
                        </item>
                        <item label="Arm/Disarm System">
                            <images>
                                <img url="images/APX32-armDisarm_01.png"/>
                                <img url="images/APX32-armDisarm_02.png"/>
                                <img url="images/APX32-armDisarm_03.png"/>
                                <img url="images/APX32-armDisarm_04.png"/>
                            </images>
                               <video>
                                   <videoPresent>true</videoPresent>
                                   <url></url>
                               </video>
                        </item>
                        <item label="Change Mastercode">
                            <images>
                                <img url="images/APX32-changeMasterCode_01.png"/>
                                <img url="images/APX32-changeMasterCode_02.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                        <item label="Secondary Codes">
                            <images>
                                <img url="images/APX32-secondaryCode_01.png"/>
                                <img url="images/APX32-secondaryCode_02.png"/>
                                <img url="images/APX32-secondaryCode_03.png"/>
                            </images>
                            <video>
                                <videoPresent>false</videoPresent>
                                   <url></url>
                               </video>
                        </item>
                        <item label="Bypass the Sensors">
                            <images>
                                <img url="images/APX32-bypassZone_01.png"/>
                                <img url="images/APX32-bypassZone_02.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                        <item label="Record/Delete Messages">
                            <images>
                                <img url="images/APX32-recordDeleteMessage_01.png"/>
                                <img url="images/APX32-recordDeleteMessage_02.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                        <item label="Set Time">
                            <images>
                                <img url="images/APX32-settingTime_01.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                        <item label="System Status">
                            <images>
                                <img url="images/APX32-systemStatus_01.png"/>
                                <img url="images/APX32-systemStatus_02.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                    </userOptions>
                      <troubleShooting>
                        <item label="AC Loss">
                            <images>
                                <img url="images/APX32-noAC_01.png"/>
                                <img url="images/APX32-noAC_02.png"/>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                            <images>
                            </images>
                            <video>
                                   <url></url>
                               </video>
                        </item>
                      </troubleShooting>
               </apx32>
            </menu>
            • 4. Re: cannot access a property or method of a null object reference
              mewk Level 3
              the data for the two lists is quite different; make sure the item renderer isn't expecting data that never gets passed in.
              can't say more w/o checking your "listRenderer."
              - e
              • 5. Re: cannot access a property or method of a null object reference
                cyber0897 Level 1
                i dont think it is...
                if you like i have attached all the relevant code for this
                the apx32Troubleshoot.mxml:
                <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                         xmlns:mx="library://ns.adobe.com/flex/halo" width="975" height="400"
                         creationComplete="app_creationComplete(event)">
                    <fx:Script source="apx32Action.as" />
                    <fx:Style>
                        @namespace s "library://ns.adobe.com/flex/spark";
                        @namespace mx "library://ns.adobe.com/flex/halo";
                        .nextButton{
                            fontSize:12;
                            textRollOverColor:#333333;
                            fontFamily:dinb;
                            fontLookup: embeddedCFF;
                    </fx:Style>
                    <mx:HBox>
                        <mx:TabNavigator width="275" height="400" paddingTop="0" tabWidth="137.5">
                            <mx:VBox label="USER OPTIONS" width="100%" height="100%" horizontalScrollPolicy="off" verticalScrollPolicy="off">
                                        borderAlpha="0" contentBackgroundColor="#e9e9e9" change="userOptionsChange(event)">
                                </s:List>
                            </mx:VBox>
                                        borderAlpha="0">
                                </s:List>
                            </mx:VBox>
                        </mx:TabNavigator>
                    </mx:HBox>
                    <mx:Image id="definition" width="700" height="375" x="275" y="24" />
                    <mx:LinkButton label="More Options" id="next" skin="{null}" x="830" y="371" visible="false" />
                </s:Group>
                listRenderer.mxml: (my item renderer)
                <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                xmlns:mx="library://ns.adobe.com/flex/halo" height="40">
                    <s:states>
                        <s:State name="normal" />
                        <s:State name="hovered" stateGroups="[hoveredStates]" />
                        <s:State name="selected" stateGroups="[selectedStates]" />
                        <s:State name="normalAndShowsCaret" />
                        <s:State name="hoveredAndShowsCaret" stateGroups="[hoveredStates]" />
                        <s:State name="selectedAndShowsCaret" stateGroups="[selectedStates]" />
                    </s:states>
                    <s:Rect left="0" bottom="1" right="1" height="2">
                        <s:fill>
                            <s:SolidColor color="0x000000" alpha=".2"/>
                        </s:fill>
                    </s:Rect>
                    <s:Rect width="100%" height="100%">
                        <s:fill>
                            <s:SolidColor color="0x6699cc" alpha="0" alpha.hoveredStates="#2c9fe1" alpha.selectedStates="#2c9fe1" />
                        </s:fill>
                    </s:Rect>
                        <mx:Label text="{data.label}" textAlign="center" x="75" verticalCenter=".5"
                                  color.normal="blue" color.hovered="#ffffff"/>
                        <mx:Image source="@Embed(source='../images/dottedDivider.gif')"  x="0" y="38"/>
                </s:ItemRenderer>
                and my actionscript to run this...
                apx32Action.as:
                // ActionScript file
                    import mx.controls.Alert;
                    import mx.core.ScrollPolicy;
                    import mx.events.FlexEvent;
                    import mx.rpc.events.FaultEvent;
                    import mx.rpc.events.ResultEvent;
                    import mx.rpc.http.HTTPService;
                    import spark.events.IndexChangeEvent;
                    [Bindable] private var menuXml:XML;
                    [Bindable] private var imgList:Object = new Object();
                    [Bindable] private var xmlReturn:Object;
                    private var currImage:int = 0;
                    [Bindable] public var imgClass:Class;
                    [Bindable] public var imgUrl:String;
                        xmlReturn = resultData;
                        //trouble.dataProvider = xmlReturn.menu.apx32.troubleShooting.item;
                //        xmlMainMenu.source = event.result.children();
                        //var test:String;
                    private function myXml_faultHandler(event:FaultEvent):void{
                        Alert.show("Error loading XML");
                        Alert.show(event.fault.message);
                    private function app_creationComplete(event:FlexEvent):void{
                        userOptions.scroller.setStyle("horizontalScrollPolicy", ScrollPolicy.OFF);
                        //trouble.scroller.setStyle("horizontalScrollPolicy", ScrollPolicy.OFF);
                        var myXml:HTTPService = new HTTPService();
                        myXml.url = "modules/apx32/apx32TroubleshootingXml.xml";
                        myXml.resultFormat = "object";
                        myXml.addEventListener(ResultEvent.RESULT, myXml_resultHandeler);
                        myXml.addEventListener(FaultEvent.FAULT, myXml_faultHandler);
                        myXml.send();
                    private function userOptionsChange(event:IndexChangeEvent):void{
                        currImage = 1;
                        imgList = event.currentTarget.selectedItems[0].images.url;
                        //definition.source = imgList[currImage];
                        imgUrl = imgList[currImage];
                        //definition.source = 'images/APX32-adjustingVolume_01.png';
                        next.visible = true;
                i use the same item renderer for both user Options, and troubleshooting... since everythign shuold just be in the source...
                im at a complete loss right now  lol
                and thanks mewk...
                • 6. Re: cannot access a property or method of a null object reference
                  mewk Level 3
                  cyber,
                  The default creation policy for all containers, except the Application container, is the policy of the parent container. The default policy for the Application container is auto. In most cases, therefore, the View Stack TabNavigator control’s children are not created until they are selected. You cannot...
                  so
                  <mx:TabNavigator creationPolicy="all">
                  There's also an error here
                  you need to keep walking the chain.
                  best o luck ,
                  - e
                  • 7. Re: cannot access a property or method of a null object reference
                    cyber0897 Level 1
                    AHA!!! that worked PERFECTLY!!! htank you soo much for the explaination!! I really appretiate it!!
                    and the error line...
                    i have no idea what the error is... ? lol... ive been trying to get the image to display on my application when i click the list item
                    ive tried things like
                    description.source = event.currentTarget.selectedItems[0].image.@url;
                    and that line seems to give me an error....
                    any ideas on that?
                    • 8. Re: cannot access a property or method of a null object reference
                      mewk Level 3
                      try
                        currImage = 1;
                        imgList = event.currentTarget.selectedItems[0].images.img;
                        definition.source = imgList[currImage]["url"];
                      - e
                      • 9. Re: cannot access a property or method of a null object reference
                        cyber0897 Level 1
                        hey mewk.. ty for all your help!!! i finally got it working !
                        the update code ended up being
                                currImage = 0;
                                imgList.source = userOptionProvider[event.newIndex].images.children();
                                definition.source = imgList[currImage].@url;
                        had to change most of my code... but the main difference was to change my xml resultFormat to e4x instead of object
