2 Replies Latest reply on Jun 10, 2010 4:55 PM by aucha
    AcroPDF.dll crash systematicaly when pressing TAB in any PDF
    Tournieux Level 1
      I am using the Acrobat ActiveX (AcoPDF.dll) for viewing PDF documents.
      When a PDF is displayed, pressing TAB key several times makes the document to scroll to the end of document.
      If I press TAB again, then the application crash.
      This happens with all PDF.
      My application is written in C++, but I did a try with the sample (AcrobatActiveXVB) provided in the SDK (9.1), witthout any modification.
      The result is the same.
      Does any body has experienced the same ? Is there a way to prevent AcroPDF to crash.
      Considering that it happens systematicly, the Reader 9 activex can not be used to display PDF.
      By the way, I did a try with the Reader 8 activeX and it worked fine without crash.
      Thanks for your help.
