[svn:fx-trunk] 12398: Updating OSMF.
rfrishbe Dec 2, 2009 4:20 PMRevision: 12398
Revision: 12398
Author: rfrishbe@adobe.com
Date: 2009-12-02 16:19:57 -0800 (Wed, 02 Dec 2009)
Log Message:
Updating OSMF.
QE notes: -
Doc notes: -
Bugs: -
Reviewer: -
Tests run: checkintests
Is noteworthy for integration: No
Modified Paths:
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/AudioElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/audio/SoundAdapter.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeMetadata.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeSeekableTrait.a s
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/CompositeViewableTrait.a s
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/composition/ParallelSwitchableTrait. as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/drm/DRMServices.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/events/MediaErrorCodes.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/HTMLGateway.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/gateways/RegionGateway.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/html/HTMLElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/html/HTMLLoadableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutRendererBase.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/LayoutUtils.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/layout/MediaElementLayoutTarget.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/LoadableMediaElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaFactory.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaInfo.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/media/MediaPlayer.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/Metadata.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataNamespaces.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataUtils.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/MetadataWatcher.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/metadata/TemporalFacet.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetLoader.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamPlayableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/NetStreamSeekableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DroppedFramesRu le.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicNetStrea m.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gNetLoader.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/DynamicStreamin gResource.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/net/dynamicstreaming/SwitchingDetail Codes.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/plugin/PluginManager.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/proxies/ProxyElement.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/tracking/Beacon.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/DownloadableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/LoadableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/LoaderBase.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/PausableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/PlayableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/traits/SwitchableTrait.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/BinarySearch.as
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/video/VideoElement.as
Added Paths:
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/OSMFStrings.as
Removed Paths:
flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/MediaFrameworkStrings.as
