8 Replies Latest reply: Mar 9, 2010 12:59 AM by jhagenst22 RSS
    Cairngorm 3 - getting started
    Peter.Coppens Community Member
      Hello,
      I extracted the Cairngorm 3 source from svn.
      Somewhat naively I typed
      mvn clean package install
      from the build-parent folder
      That gave all kinds of missing dependencies most of which I was able to resolve using the libraries available in the svn extract
      Currently I am still missing 2 which I can't seem to fix
      1) org.spicefactory:cinnamon:swc:1.0.1
      2) com.adobe.flexunit:flexunit:swc:4.0-beta-2-eventful
      Is what I am trying to do not intended? Any other guidance as on how to resolve this?
      Many thanks indeed
      Peter
        • 1. Re: Cairngorm 3 - getting started
          François Le Droff Adobe Employee
          Hello Peter,
          As you guessed you need to install the swc in your maven repository.
          Locally what we have is a nexus server serving all those dependencies, unfortunately this nexus server is not public.
          Let's hope it will be one day.
          meanwhile the two swc you are missing should be available in the flexunit4 project swcs (on opensource.adobe.com)
          the cinnamon swc is a spicefactory project, you will find it, on their web site.
          Nevertheless I'll do my best to publish a decent repository at some point, I wished I had the time to do it now.
          Cheers,
          François
          • 2. Re: Cairngorm 3 - getting started
            François,
            Thanks for taking the time to help me
            I found what I needed wrt the cinnamon dependancy I think. I am however less certain what swc from the flexunit download I need to attach to com.adobe.flexunit:flexunit:swc:4.0-beta-2-eventful.
            Would you have any guidance there?
            Thanks!
            Peter
            • 3. Re: Cairngorm 3 - getting started
              Hello Peter,
              Thanks for the feedback I double checked, and you are right it does not make much sense and I could not figure out where this swc was supposed to be released.
              So I refactored a bit the code and now you should just depend on flexunit 4 beta 2.
              Update the source code from svn, you'll see !
              Cheers !
              François
              • 4. Re: Cairngorm 3 - getting started
                Hello François,
                Seems as I go along I run into new dependencies that are difficult to get at.
                1) com.adobe.lcds:fds_rb:rb.swc:en_US:2.6.1
                2) com.adobe.lcds:fds:swc:2.6.1
                3) com.adobe.lcds:playerfds:swc:2.6.1
                This is currently missing.
                Perhaps I should just wait a bit before trying to give Cairngorm 3 a test drive
                Any guidance?
                Peter
                • 5. Re: Cairngorm 3 - getting started
                  These one are lcds (LiveCycle Data Service), and so you need to download lcds 2.6.1.
                  This is not open source software, it should only be needed by the library IntegrationDM.
                  Cheers !
                  François
                  PS: Cairngorm 3 is still beta but you may also test drive cairngorm3 by downloading the released beta swc, look at the wiki
                  • 6. Re: Cairngorm 3 - getting started
                    Alex Uhlmann Community Member
                    Hi Peter,
                    while we use Maven/Hudsion internally to build and control quality of Cairngorm 3 libraries, it wasn't our main priority at this point to also let others leverage this infrastructure. Just out of time/resource constraints we currently focus on guidelines and libraries around client side architecture. However, at a later point, we do plan to share more information on build automation and look forward to exchange ideas around this area. That said, why does this prevent you from viewing the current content i.e. around libraries?
                    Alex
                    • 7. Re: Cairngorm 3 - getting started
                      Thanks for the answers.
                      I was unaware a binary beta download was out there somewhere. I will try to find it.
                      Currently not much seems to be working on the wike
                      http://opensource.adobe.com/wiki/display/cairngorm/ results in a confluence system error
                      org.springframework.transaction.UnexpectedRollbackException: Transaction rolled back because it has been marked as rollback-only
                      at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(Abstrac tPlatformTransactionManager.java:626)
                      Stack Trace: [hide]
                           at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:626)
                           at com.atlassian.xwork.interceptors.XWorkTransactionInterceptor$1.beforeResult(XWorkTransactionInterceptor.java:89)
                           at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:181)
                           at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:35)
                           at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:165)
                      Peter
                      • 8. Re: Cairngorm 3 - getting started
                        jhagenst22 Adobe Employee
                        fds-2.6.1.swc
                        fds_rb-2.6.1.rb.swc
                        Those two I found under
                        cairngorm3/tags/Integration-0.2/libraries/Integration/libs/
                        they were synced from SVN:
