0 Replies Latest reply on Dec 2, 2009 4:56 PM by Glenn Ruehle
    [svn:fx-trunk] 12401: Spark (SkinnableContainer) creationPolicy was a simple property.
    Glenn Ruehle Adobe Employee
      Revision: 12401
      Revision: 12401
      Author:   gruehle@adobe.com
      Date:     2009-12-02 16:55:48 -0800 (Wed, 02 Dec 2009)
      Log Message:
      Spark (SkinnableContainer) creationPolicy was a simple property. The mx (Container) creationPolicy property had logic to inherit the parent's creation policy if not explicitly specified, but this only worked if the parent was also a Container.
      This change makes SkinnableContainer.creationPolicy an inheriting property, and fixes mx Containers so they can inherit creationPolicy from SkinnableContainer parents. This is all done behind the scenes by using a private inheriting style for backing storage.
      QE notes: Yes, tests need updating for new behavior
      Doc notes: No
      Bugs: SDK-23955
      Reviewer: Ryan
      Tests run: checkintests, extensive cyclone testing
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23955
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/NavigatorContent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
