6 Replies Latest reply on Dec 3, 2009 11:12 PM by pixlor
    Duration problem with animated gif
    cginsberg
      Hi!
      I love the animated gif feature and have used it several times successfully.
      This time, it seems to ignoring my settings for duration. I've set the number as high as 1500/100, but when I preview in browser (Mac Safari or Firefox), the images just whip by. I did slice the animated area and optimize it as an animated gif and export it. When I worked with it again this morning, the first image reflected the 1500/100, but the rest are still racing. I've tried to attach file here.
      Also, I'm wondering if this really should be done in Flash rather than FW. The client wants maybe 5 or 6 images and with the 7 test I have now, I see we're at 216K file size. I don't know flash but if the blog theme we use doesn't have something set up, I assume I'll just outsource the Flash development.
      Caryn
        • 1. Re: Duration problem with animated gif
          pixlor Level 4
          In that image, the duration for the first frame is 500. The remaining frames are 7. Open the Frames panel and set the duration for each frame individually.
          (This is the CS3 interface, your version may be different. The Frames panel should be under the Windows menu.)
          For your other question, the .gif format is not the best format for photographic images, since you can only have 256 colors. You might want to check on image rotators or, yes, Flash.
          • 2. Re: Duration problem with animated gif
            cginsberg Level 1
            Thanks so much for quick helpful response, pixlor!
            Okay, this is consistent with something I'm seeing. I change the settings for duration, but they don't "stick" even when I save the file. I just reopened it and I see 1500 next to all the frames / states. But it's still acting on the 500 / 7 settings. Earlier when I had the file open, I saw the 500 / 7 and then as I watched, it seemed to change to all 1500.
            Any thoughts?
            I think we will take this to Flash ultimately. But since I don't know that and don't want to learn, I'm hoping to understand this gif problem, just so I can show the client a rough in FW.
            • 3. Re: Duration problem with animated gif
              cginsberg Level 1
              Thought it might be a cache issue based on another thread I read, but I cleared and tried a couple times with no luck.
              I notice my setting to stop at 3 loops isn't "sticking" either.
              • 4. Re: Duration problem with animated gif
                pixlor Level 4
                Okay...it works for me, but....
                One thing to be careful of is saving vs. exporting. When you create your file, you should save it as a Fireworks .png document. Then, to produce your animated .gif, you should export it. I like using the Image Preview (under the File menu), as I can tweak any of the settings I want. Other people prefer the Export item and optimize their output.
                There are two kinds of .png files. A Fireworks .png has all the layers, vector shapes, Web layer, active filters, and special proprietary information that Fireworks uses. A flattened .png is just a bitmap, whether it has 32, 24, or 8 bits. There's no distinction between these files based on the extension. Another user once suggested using .fw.png for Fireworks documents and .png for exported .pngs and I found that a good suggestion.
                In any case, a good rule to follow is to use save when you want a Fireworks .png and export when you want a Web-ready bitmap of any format.
                So, this is my "but." I took your file and changed the durations of the other frames. I saved it as a Fireworks .png. I then went to File > Image Preview and selected Animated GIF as the format. From the Animation tab, I set the number of loops to 3 and exported. I then saved the .png again to store the loop information.
                Here's the .png (474k):
                Here's the animation (303k):
                Given that the .gif format does't have the colors to reproduce photographs well, I still recommend you look into image rotators. These are scripts that can cycle through a set of images. See this thread:
                http://forums.adobe.com/thread/518231?tstart=1
                • 5. Re: Duration problem with animated gif
                  cginsberg Level 1
                  Thanks so much for the help and the files. I see several places I may have gone wrong. Great example of doing something a few times and thinking you know how to do it, when you really need to slow down and reread the instructions.
                  I really appreciate your time to provide both a fixed file and all the coaching. Now I can get something to my client quickly and go back and review the notes as needed in the future.
                  Inspired,
                  Caryn
                  • 6. Re: Duration problem with animated gif
                    pixlor Level 4
                      Happy to help!
