• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Error running flex PMD in Ant
New Here ,
Dec 03, 2009 Dec 03, 2009
Hi Guys
I'm trying to get Flex PMD running in my ant build but am running into a few problems.
My task definition:
    <property name="flexpmd.version" value="1.0.RC5" />
    <property name="flexpmd.dir" value="${LIBS.dir}/flexpmd" />
<taskdef name="flexPmd"
classname="com.adobe.ac.pmd.ant.FlexPmdAntTask"
classpath="${flexpmd.dir}/flex-pmd-ant-task-${flexpmd.version}.jar"
        <classpath>
            <pathelement location="${flexpmd.dir}/flex-pmd-ruleset-api-${flexpmd.version}6.jar"/>
            <pathelement location="${flexpmd.dir}/flex-pmd-ruleset-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/flex-pmd-core-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/as3-plugin-utils-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/as3-parser-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/pmd-4.2.2.jar"/>
            <pathelement location="${flexpmd.dir}/commons-lang-2.4.jar"/>
            <pathelement location="${flexpmd.dir}/flex-pmd-files-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/as3-parser-api-${flexpmd.version}.jar"/>
            <pathelement location="${flexpmd.dir}/plexus-utils-1.0.2.jar"/>
        </classpath>
</taskdef>
and my results:
C:\dev\workspaces\RTC\UUI_Core_ANT>ant -f buildLocalDebug.xml
Buildfile: buildLocalDebug.xml
Trying to override old definition of task manifest
createCoreFileSystem:
compileLocalDebugCoreLibs:
compileCoreLib:
[manifest] running manifest generator
[manifest] done
[manifest] done
[manifest] done
    [compc] Loading configuration file C:\dev\flexsdk\4.0.0.10708\frameworks\fle
x-config.xml
    [compc] Loading configuration file C:\dev\workspaces\RTC\UUI_Shared_ANT\flex
-config.xml
    [compc] C:\dev\workspaces\RTC\UUI_Shared_Libs\UUI\UUI_Core.swc (1996936 byte
s)
BUILD FAILED
C:\dev\workspaces\RTC\UUI_Core_ANT\buildLocalDebug.xml:16: The following error o
ccurred while executing this line:
C:\dev\workspaces\RTC\UUI_Core_ANT\includes\UUI_Core.xml:55: java.lang.NoClassDe
fFoundError: net/sourceforge/pmd/RuleSetFactory
Total time: 5 seconds
The task def is ok as I don't get an error at the start, only when the task tries to run. I've had a look at the jars in the zip I downloaded and can't find the RuleSetFactory class anywhere.
I have just today downloaded the latest ant zip so must have the latest version. Any ideas?
TOPICS
FlexPMD
Views
816
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Dec 03, 2009 Dec 03, 2009
It looks like the pmd.4.2.5 jar is not in the source path...
Xavier
Votes
Translate
Translate
Adobe Employee ,
Xavier
Votes
Translate
Translate
Report
Report
New Here ,
Dec 04, 2009 Dec 04, 2009
LATEST
That jar file was in the source path but my task def was looking for the wrong version. Unfortunately ANT doesn't tell you if it can't find the files you reference in the pathelement tags.
Updating the filename fixed it, thanks
Votes
Translate
Translate
Report
Report
