• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CSS change works on my hard drive, not on network??
New Here ,
Dec 03, 2009 Dec 03, 2009
I'm using RH8 and generating web help. I have several tables that require the header row text to be rotated 270 degrees. To accomplish this, I added the following filter to the CSS: filter: progid:DXImageTransform.Microsoft.BasicImage(rotation=3);
When I generate web help on my hard drive, it looks great. If I publish it to the network or copy the !SSL! folder to the network, the cell heading text appears normal with no rotation. Any ideas?
Here's a clip from the CSS:
p.CellHeading {
margin-left: 0.000pt;
margin-right: 0.000pt;
text-align: left;
text-indent: 0.000pt;
margin-top: 0.000pt;
margin-bottom: 0.000pt;
word-spacing: 0.250em;
color: #000000;
letter-spacing: 0.00em;
font-family: Arial;
font-style: italic;
font-size: 10pt;
text-decoration: none;
By the way, I don't know just enough about CSS and HTML to get by with very basic stuff - I'm a real amateur when it comes to coding.
Views
988
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
RoboHelp has a habit of changing your css on generating output. Try pasting your original CSS in your output folder, it should all work then.
Just note the a filter only works in IE. Check out http://snook.ca/archives/html_and_css/css-text-rotation for some more info on rotating text. (You will need to get creative to feed all the browsers the correct css so they will all display the text correct).
Greet,
Willam
PS. You can replace stuf like margin-left: 0.000pt with margin-left: 0;
Votes
Translate
Translate
Report
Report
New Here ,
No luck. I also compared the CSS files and they match exactly.
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 04, 2009 Dec 04, 2009
That's rather peculiar...
Do you open the WebHelp on the network with exactly the same browser as your local browser (Internet Explorer, same version?).
I couldn't find anyting on it, but it might be a security setting. Try adding the webhelp location to the trusted sites.
The MSDN-site has a comprehensive article about css filters: http://msdn.microsoft.com/en-us/library/ms532847%28VS.85%29.aspx you may find some more usefull information there.
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Thanks Willam, but that didn't seem to help. My network address starts with \\nas - would that be a problem? (Everything else looks great - just that filter. Argh!)
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 07, 2009 Dec 07, 2009
I don't see why that's a problem, unless it's a security issue. I tested your style on several locations with IE8 and IE7. With me, it allways worked with IE8, but never with IE7. I suspect that this could be a but, since the filter should also work on paragraphs.
The MSDN-page on the BasicImage filter is: http://msdn.microsoft.com/en-us/library/ms532972%28VS.85%29.aspx
Can you try the examples provided on that page?
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Okay, looks like we're getting somewhere! I got it to work when I pasted one of the examples straight into the html code of the topic page (not the CSS), but I'm not sure how to apply it to the table headings. I'm attaching the code for the topic page as well as a screen shot of what it I want it to look like. Thanks for your help, Willam - you don't know how many hours of grief this has given me!
-Bill.
Votes
Translate
Translate
Report
Report
LEGEND ,
There are two way's of doing this:
In the heading of the document (before </head>), add a style block, like this:
<style type="text/css">
     p.CellHeading {filter:progid:DXImageTransform.Microsoft.BasicImage(rotation=3);}
</style>
This might give you the same problems. You can also attach the style directly to the element, in this case p.CellHeading. In the code, look for for <p class="CellHeading"> and add before the >:
style="filter:progid:DXImageTransform.Microsoft.BasicImage(rotation=3);" so it will look like this: <p class="CellHeading" style="filter:progid:DXImageTransform.Microsoft.BasicImage(rotation=3);">
If there's a style block already, just add it behind the last ;, like: <p class="CellHeading" style="color: #bf0000; filter:progid:DXImageTransform.Microsoft.BasicImage(rotation=3);">High
         background events</p>
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
No luck. For some reason the table is causing problems. Do you see anything unusual about it in the code?
Votes
Translate
Translate
Report
Report
New Here ,
Do I need a <div> tag somewhere?
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 08, 2009 Dec 08, 2009
I don't see anything right away. It has a lot of inline styling, but that shouldn't be a problem. It's strange that it will work on one location, but not on another...
It's unlikely that you'll need a <div> tag, as that's only a block element. Commonly used to position content on a page, moreover, according to the MSDN-site, it also works on paragraphs.
I have some more time tomorrow and I'll look into it to see if I can find anyting.
Greet,
Willam
Votes
Translate
Translate
Report
Report
LEGEND ,
Dec 11, 2009 Dec 11, 2009
Not much I can find, just my own test findings.
The filter works perfectly fine in IE8 for me, regardless of the filter being in css or inline. It however doesn't work on IE7.
The filter works on images in IE6 - IE8.
As to why it works locally and not on a network drive, I don't have the faintest idea.
Sorry, but I can't help any further.
Greet,
Willam
Votes
Translate
Translate
Report
Report
New Here ,
Dec 15, 2009 Dec 15, 2009
LATEST
Okay, thanks Willam. I appreciate all your help.
-Bill.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
