4 Replies Latest reply on Dec 3, 2009 1:05 PM by Jacob Bugge
    Export to PNG
    panfried Level 1
      Why does an exported png file crop a portion of this image? Thank you! Using CS3.
        • 1. Re: Export to PNG
          Jacob Bugge MVP & Adobe Community Professional
          panfried,
          Just a guess: because the cropping corresponds to the spines rather than to the outermost part of strokes.
          With stroked paths, you cannot count on the Bounding Box/Transform palette, unless you have Preview Bounds on (Preferences>General).
          • 2. Re: Export to PNG
            panfried Level 1
            Thanks, Jacob.
            There are no strokes, just paths. Is there a setting that I'm missing?
            • 3. Re: Export to PNG
              Most likely you are doing everything right, it's just AI not correctly calculating the pixel content. A simple way to avoid it would be to apply an "inert" effect (e.g. drop shadow with 0% opacity) and then adjust the document raster effect resolution to add just enough pixels around such effects so your text doesn't get cropped.
              Mylenium
              • 4. Re: Export to PNG
                panfried,
                Is the artwork, and its cropping, aligned with a grid a whole pixels? If it is, the Y value in the Transform palette with one of the lowest Reference Points chosen will be an integer point/pixel value (the same applies to the other three sides).
