4 Replies Latest reply on Dec 28, 2011 2:01 PM by YogLC
    Exception in XMLFormService org.omg.CORBA.COMM_FAILURE
    YogLC Level 1
      Hi I am trying to use the FormService from ES2 using  servlet / JSP (java/EJB)  client to invoke it. I see following exception.
      I observed that  if the xml data passed is reduced in size then I don't get this error (strange) , I had tried same sample with 8.2 which was working fine.
      Any idea?
      YogLC
      2009-12-03 12:18:09,659 WARN  [jacorb.giop.conn] Abnormal connection termination. Lost 1 outstanding replie(s)!
      2009-12-03 12:18:09,690 ERROR [com.adobe.formServer.PA.XMLFormAgentWrapper] ALC-FRM-001-013: XMLFormFactory, PAexecute failure: "org.omg.CORBA.COMM_FAILURE"
      2009-12-03 12:18:09,784 WARN  [com.adobe.service.ProcessResource] BMC024: Service XMLFormService: Process
      ProcessResource@99334e(name=XMLForm.exe,pid=2216) terminated abnormally with error code {3}
      2009-12-03 12:18:18,581 ERROR [com.adobe.service.ProcessResource] BMC001: Unexpected exception while rolling back transaction
      org.omg.CORBA.TRANSIENT: Retries exceeded, couldn't reconnect to 127.0.0.1:2937  vmcid: 0x0  minor code: 0  completed: No
      at org.jacorb.orb.iiop.ClientIIOPConnection.connect(Unknown Source)
      at org.jacorb.orb.giop.GIOPConnection.sendMessage(Unknown Source)
      at org.jacorb.orb.giop.GIOPConnection.sendRequest(Unknown Source)
      at org.jacorb.orb.giop.ClientConnection.sendRequest(Unknown Source)
      at org.jacorb.orb.Delegate.invoke_internal(Unknown Source)
      at org.jacorb.orb.Delegate.invoke(Unknown Source)
      at org.omg.CORBA.portable.ObjectImpl._invoke(ObjectImpl.java:457)
      at com.adobe.service._ControlAgentStub.done(_ControlAgentStub.java:106)
      at com.adobe.service.ProcessResource.onRollback(ProcessResource.java:975)
      at com.adobe.service.ResourcePeer.invokeRollback(ResourcePeer.java:124)
      at com.adobe.service.J2EEResourcePeerImpl.afterCompletion(J2EEResourcePeerImpl.java:190)
      at com.arjuna.ats.internal.jta.resources.arjunacore.SynchronizationImple.afterCompletion(Syn chronizationImple.java:136)
      at com.arjuna.ats.arjuna.coordinator.TwoPhaseCoordinator.afterCompletion(TwoPhaseCoordinator .java:340)
      at com.arjuna.ats.arjuna.coordinator.TwoPhaseCoordinator.cancel(TwoPhaseCoordinator.java:107 )
      at com.arjuna.ats.arjuna.AtomicAction.abort(AtomicAction.java:201)
      at com.arjuna.ats.internal.jta.transaction.arjunacore.TransactionImple.rollbackAndDisassocia te(TransactionImple.java:1451)
      at com.arjuna.ats.internal.jta.transaction.arjunacore.BaseTransaction.rollback(BaseTransacti on.java:163)
      at com.arjuna.ats.jbossatx.BaseTransactionManagerDelegate.rollback(BaseTransactionManagerDel egate.java:126)
      at org.jboss.ejb.EnterpriseContext$UserTransactionImpl.rollback(EnterpriseContext.java:715)
      at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:228)
      at sun.reflect.GeneratedMethodAccessor663.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
        • 1. Re: Exception in XMLFormService org.omg.CORBA.COMM_FAILURE
          azathoth_ Level 1
          I'm facing the same situation here, using LC ES, does anyone know what causes XMLForm.exe to terminate abruptly?
          • 2. Re: Exception in XMLFormService org.omg.CORBA.COMM_FAILURE
            pdibenedetto
            Any updates on this issue?
            • 3. Re: Exception in XMLFormService org.omg.CORBA.COMM_FAILURE
              YogLC Level 1
              Now I have simillar error on Assembler service see below for details.
              Help is required on this.
              YogLC
              WARNING: "IOP00410215: (COMM_FAILURE) Read of full message failed : bytes reque
              ted = 3,751,880 bytes read = 956,320 max wait time = 3,000 total time spent wai
              ing = 3,190"
              org.omg.CORBA.COMM_FAILURE:   vmcid: SUN  minor code: 215  completed: No
                      at com.sun.corba.se.impl.logging.ORBUtilSystemException.transportReadTi
              eoutExceeded(ORBUtilSystemException.java:2600)
              eoutExceeded(ORBUtilSystemException.java:2626)
                      at com.sun.corba.se.impl.transport.SocketOrChannelConnectionImpl.readFu
              ly(SocketOrChannelConnectionImpl.java:628)
                      at com.sun.corba.se.impl.transport.SocketOrChannelConnectionImpl.read(S
              cketOrChannelConnectionImpl.java:559)
                      at com.sun.corba.se.impl.protocol.giopmsgheaders.MessageBase.readGIOPBo
              y(MessageBase.java:413)
                      at com.sun.corba.se.impl.transport.CorbaContactInfoBase.finishCreatingM
              ssageMediator(CorbaContactInfoBase.java:183)
                      at com.sun.corba.se.impl.transport.SocketOrChannelConnectionImpl.finish
              eadingBits(SocketOrChannelConnectionImpl.java:380)
                      at com.sun.corba.se.impl.transport.SocketOrChannelConnectionImpl.doWork
              SocketOrChannelConnectionImpl.java:1208)
                      at com.sun.corba.se.impl.orbutil.threadpool.ThreadPoolImpl$WorkerThread
              performWork(ThreadPoolImpl.java:471)
              run(ThreadPoolImpl.java:500)
              Dec 28, 2011 1:23:36 PM com.adobe.idp.DocumentManagerClient requestRemotePassiv
              tion
              • 4. Re: Exception in XMLFormService org.omg.CORBA.COMM_FAILURE
                YogLC Level 1
                Ok, I think I have answer need to extend timeout on client and server.
                Modify jvm parameter for both client and server.
                i) For server add JVM parameter (run.bat for JBoss)  new parameter while starting.
                "-Dcom.sun.CORBA.transport.ORBTCPReadTimeouts=1:15000:300:1"
                ii) For clients pass JVM parameter whilce invoking any LCES service
                   e.g. for client using ant use  jvmarg  tag
                <jvmarg value="-Dcom.sun.CORBA.transport.ORBTCPReadTimeouts=1:15000:300:1"/>
                That worked for me.
                YogLC
