1 Reply Latest reply on Dec 3, 2009 12:41 PM by Steve Grisetti
    help with pe 7 capture pixellation?
    AlonsoQ
      i'm new to premiere elements 7 & am trying to eliminate small pixellations.  I'm using this setup:
        dual core 2.6 pentium/4gb/upscale video/7200sata2 HD that's nearly empty/pci-express firewire
        canon hv20/mini-dv  hd camera
      in premiere elements 7, it controls my tape if I choose get media & then dv camera, but
      doesnt' recognize anything attached if i choose get media & then hdv camera
      about half my 30 minutes of a mini-dv tape gets captured, but about half with pixellations displayed
      on the right side of the frame.
      if i continue as just a 'dv' camera, the 'capturing source' shows as microsoft and I don't see how to change it.
      if I start a new project; and choose ntsc/hdv; I don't know whether to choose
        1080/interlaced or
         720 / progressive
      but either setting seems to lead to the same minor pixellation
      I don't see a way to tell the project setup that I have a canon hd camera ...
      i'm hoping there's a way to capture w/o pixellation with the current hardware.
      suggestions?
        • 1. Re: help with pe 7 capture pixellation?
          When you are trying to capture HDV, is your project set up with HDV settings and your Device Control set to HDV?
          You've got some strange stuff going on that defies easy explanation. If you're having no luck capturing with Premiere Elements, try these two, free capture utilities:
          For capturing DV footage, try WinDV.
          For capturing HDV footage, try HDV Split.
          Both programs can be found easily with a Google search, and the files they capture over FireWire are perfectly compatible with Premiere Elements.
          But if you're having problems with these programs also, you may need to look a bit deeper for a solution.
          (You don't say what operating system you're using, but go to Windows Update and ensure you have even the optional updates and make sure you have the latest Quicktime, which plays a key role in any video editing.)
