0 Replies Latest reply on Dec 3, 2009 2:04 PM by jmurphy67
    [svn:fx-trunk] 12469: fix offsets for FB.
    jmurphy67 Level 1
      Revision: 12469
      Revision: 12469
      Author:   jimurphy@adobe.com
      Date:     2009-12-03 14:04:16 -0800 (Thu, 03 Dec 2009)
      Log Message:
      fix offsets for FB.  Convert line ending from lf to crlf in svn for the proects directory only.  When checking project files in, be sure to save you files this way.  Another update to make sure happens is set the svn properties svn:eol-style = native and svn:mime-type = text/plain (these have been updated on theses files as well)
      QE notes: make sure the proper class is selected
      Doc notes: no
      Bugs: http://bugs.adobe.com/jira/browse/SDK-24498
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/asdoc/en_US/spark/components/examples/Win dowedApplicationSample.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/fileSystemClasses/FileSys temComboBoxRenderer.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/controls/fileSystemClasses/FileSys temDataGridNameColumnRenderer.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/events/WindowExistenceEvent.as
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/ColorDodgeShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFillMode.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/LuminosityMask Shader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/validators/NumberValidatorDomainType. as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/Applicatio nContainerExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/BorderCont ainerExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DataRenderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HGroup.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/IItemRenderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/IItemRendererOwner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpPosition.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VGroup.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoDisplay.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/DynamicStreami ngVideoItem.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/DynamicStreami ngVideoSource.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/mediaClasses/ScrubBar.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/Invalidating Sprite.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Animate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateColor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransitionShader.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/CrossFade.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Resize.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Wipe.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/WipeDirection.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Keyframe.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/MotionPath.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Timeline.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/easing/EaseInOutBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/easing/IEaser.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/easing/Linear.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/easing/Power.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/easing/Sine.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/HSBInterpolator. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/IInterpolator.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/MultiValueInterp olator.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/NumberInterpolat or.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/interpolation/RGBInterpolator. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateColorIns tance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransiti onShaderInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/RotateInstance. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/Block.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LayoutBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TabBarButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPa useButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ContainerBorderSkin.as
          flex/sdk/trunk/frameworks/projects/utilities/src/MyFlexContentHolder.as
      Property Changed:
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/ColorBurnShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/ColorShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/ExclusionShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/HueShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/LuminosityMaskShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/LuminosityShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/SaturationShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/graphics/shaderClasses/exampl es/SoftLightShaderExample.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IVisualElement.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/ColorBurnShade r.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/ColorDodgeShad er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/ColorShader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/ExclusionShade r.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/HueShader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/LuminosityShad er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/SaturationShad er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/shaderClasses/SoftLightShade r.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/WindowBackground.as
          flex/sdk/trunk/frameworks/projects/osmf/src/org/osmf/utils/OSMFStrings.as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/LabelExamp le.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/ListExampl e.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/RichTextEx ample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/BitmapImag eExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/EllipseExa mple.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/LineExampl e.mxml
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/RectExampl e.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/ButtonBarAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/ButtonBaseAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/CheckBoxAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/ListBaseAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/NumericStepperAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/PanelAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/RadioButtonAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/SliderBaseAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/SpinnerAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/TextAreaAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/accessibility/TextInputAccImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/BorderContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TileGroup.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TrackBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/IViewport.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/CallAction.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/SetAction.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/SimpleMotionPath.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/CallActionInsta nce.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/ResizeInstance. as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/SetActionInstan ce.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/DropDownEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/IndexChangeEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/RendererExistenceEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/TrackBaseEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/VideoEvent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LinearLayoutVec tor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderContainerSkin.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSki n.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/styles/metadata/BasicInheritingTextSty les.as
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TabBarSkin.mxml
