0 Replies Latest reply on Dec 3, 2009 5:04 PM by GordonSmith
    [svn:fx-trunk] 12478: The partAdded() and partRemoved() methods of Spark components now dispatch new events named "partAdded" and  "partRemoved", of type SkinPartEvent.
    GordonSmith Level 4
      Revision: 12478
      Revision: 12478
      Author:   gosmith@adobe.com
      Date:     2009-12-03 17:03:50 -0800 (Thu, 03 Dec 2009)
      Log Message:
      The partAdded() and partRemoved() methods of Spark components now dispatch new events named "partAdded" and "partRemoved", of type SkinPartEvent. The accessibility implementation classes will soon use these events to know when skin parts are added and removed so that they can attach and remove event handlers appropriately. This mechanism may change in a future release, so developers should not depend on these undocumented events.
      I've made sure that all overrides of partAdded() and partRemoved() call the supermethod so that they dispatch these events.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Deepa
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableDataContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TextArea.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/TitleWindow.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBarBas e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownList Base.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/TrackBase.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/events/SkinPartEvent.as
