4 Replies Latest reply on Nov 18, 2011 2:08 AM by Ing81
    End of my tether with AxisRenderer gutters bug - please help
    rrodseth
      Any charting developers here? I've spent a couple of days on this already and would appreciate troubleshooting or workaround ideas.
      In AxisRenderer.as (line 2200 in sdk3.3) we find a reference to "lastLabel" which will be null if there is only one label, because it is computed as _labels[1].
      Excerpt from AxisRenderer.calcStaggeredSpacing:
              lastLabel = _labels[1];
              if (adjustable.left == false)
                  staggeredScale = Math.min(
                      staggeredScale,
                      staggeredleftGutter / (firstLabel.width / 2));
              if (adjustable.right == false)
                      staggeredScale,
                      staggeredrightGutter / (lastLabel.width / 2));      // (me) Here's where the NPE occurs.
      Stack Crawl:
      __________
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at mx.charts::AxisRenderer/calcStaggeredSpacing()[C:\work\flex\dmv_automation\projects\datav isualisation\src\mx\charts\AxisRenderer.as:2200]
          at mx.charts::AxisRenderer/calcRotationAndSpacing()[C:\work\flex\dmv_automation\projects\dat avisualisation\src\mx\charts\AxisRenderer.as:1591]
          at mx.charts::AxisRenderer/adjustGutters()[C:\work\flex\dmv_automation\projects\datavisualis ation\src\mx\charts\AxisRenderer.as:1331]
          at mx.charts::AxisRenderer/set gutters()[C:\work\flex\dmv_automation\projects\datavisualisation\src\mx\charts\AxisRender er.as:803]
          at mx.charts.chartClasses::CartesianChart/updateAxisLayout()[C:\work\flex\dmv_automation\pro jects\datavisualisation\src\mx\charts\chartClasses\CartesianChart.as:2032]
          at mx.charts.chartClasses::CartesianChart/updateDisplayList()[C:\work\flex\dmv_automation\pr ojects\datavisualisation\src\mx\charts\chartClasses\CartesianChart.as:1359]
          at mx.core::UIComponent/validateDisplayList()[C:\autobuild\3.3.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:6351]
          at mx.managers::LayoutManager/validateDisplayList()[C:\autobuild\3.3.0\frameworks\projects\f ramework\src\mx\managers\LayoutManager.as:622]
          at mx.managers::LayoutManager/doPhasedInstantiation()[C:\autobuild\3.3.0\frameworks\projects \framework\src\mx\managers\LayoutManager.as:695]
          at Function/http://adobe.com/AS3/2006/builtin::apply()
          at mx.core::UIComponent/callLaterDispatcher2()[C:\autobuild\3.3.0\frameworks\projects\framew ork\src\mx\core\UIComponent.as:8633]
          at mx.core::UIComponent/callLaterDispatcher()[C:\autobuild\3.3.0\frameworks\projects\framewo rk\src\mx\core\UIComponent.as:8573]
      Context from AxisRenderer:
      (Note: the second branch of the if statement is executing, thus adjustment.bottom is false which leads to the code path with the bug.)
      public function set gutters(value:Rectangle):void
              var correctedGutters:Rectangle = value;
              // This check will rarely succeed, because _gutters
              // have been tweaked to represent placement.
              if (_gutters &&
                  _gutters.left == correctedGutters.left &&
                  _gutters.right == correctedGutters.right &&
                  _gutters.top == correctedGutters.top &&
                  _gutters.bottom == correctedGutters.bottom)
                  _gutters = correctedGutters;
                  return;
              else
                  adjustGutters(value,
                      { left: false, top: false, right: false, bottom: false });
      I am building the series list dynamically, it's a stacked column chart, and for me the bug occurs when there is one series and one data point.
      I haven't been able to trigger the bug with the following example, which has a similar structure to my actual code.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"  xmlns:local="*">
      <mx:Script>
          <![CDATA[
              import mx.charts.series.ColumnSeries;
              import mx.charts.chartClasses.Series;
              [Bindable]
              public var seriesList:Array = [];
              public function buildSeriesList(seriesList:Array):Array {
                  var chartSeries:Array = new Array();
                  var index:int = 0;
                  for each (var series:Object in seriesList) {
                              var columnSeries:ColumnSeries = new ColumnSeries();
                              columnSeries.dataProvider = series.items;
                              columnSeries.dataFunction = myDataFunction;
                              columnSeries.displayName = series.category;
                              chartSeries.push( columnSeries );
                  return chartSeries;
                  private function categoryProvider(seriesList:Array):Array {
                      if (seriesList && seriesList.length > 0)
                          return (seriesList[0]).items;
                      return null;
                  private function myDataFunction(series:Series, item:Object, fieldName:String):Object {
                      if(fieldName == "yValue") {
                          return item.value;
                      else if(fieldName == "xValue") {
                          return item.category;
                      else
                          return null;
                       public function shortCategoryLabel(source:String):String {
                          return source;
                       public function longCategoryLabel(source:String):String {
                          return source;
                    private function onRefresh(event:Event):void {
                          this.seriesList = [ { category: "cat1" , items: [ { category: "Default Business Unit", value:574.1 }] }];
      </mx:Script>
          <mx:Button label="Refresh" click="onRefresh(event)" />
          <mx:ColumnChart height="100%"
                  width="100%" type="stacked" series="{this.buildSeriesList(this.seriesList)}">
                      <mx:horizontalAxis>
                          <mx:CategoryAxis id="bottomAxis2" title="Horizontal Axis"
                              dataProvider="{this.categoryProvider(this.seriesList)}"
                              categoryField="category"
                      </mx:horizontalAxis>
                       <mx:verticalAxis>
                          <mx:LinearAxis id="leftAxis2" title="Vertical Axis"/>
                      </mx:verticalAxis>
                   <mx:verticalAxisRenderers>
                      <mx:AxisRenderer
                          placement="left" styleName="verticalAxisRenderer"
                          axis="{leftAxis2}"  verticalAxisTitleAlignment="vertical"
                  </mx:verticalAxisRenderers>
                      <mx:horizontalAxisRenderers>
                          <mx:AxisRenderer
                              placement="bottom"
                              axis="{bottomAxis2}"  verticalAxisTitleAlignment="flippedVertical"
                          </mx:AxisRenderer>
                      </mx:horizontalAxisRenderers>
          </mx:ColumnChart>
      </mx:Application>
