4 Replies Latest reply on Dec 3, 2009 5:32 PM by the_wine_snob
    Elements 7 - Memory Errors
    davalle
      I am using Premiere Elements 7, and have created numerous files.
      One file opens fine, and I can burn to a DVD.
      When I open the other files, an error appears "Adobe Premiere Elements is running very low on system memory.  Please save your project and continue working with caution."
      I can try to continue working, and sometimes it will freeze, and say the program has serious errors, needs to shut down, etc.  Other times I can continue working up until burning stage, and at the last minute of burning, it will come up with an error saying "memory allocation error".
      I can't get these files to burn to a DVD.  I have tried numerous times.
      Can anyone please help!!  I have all this footage of my daughter I would like to get into a DVD.  I have a new PC, with 4GB RAM, make sure my computer is freshly rebooted, and don't have any other applications running.
        • 1. Re: Elements 7 - Memory Errors
          the_wine_snob Level 9
          "System Memory" is a combo of RAM and Windows Virtual Memory (Page File). Something(s) is/are stealing your resources.
          This ARTICLE will give you tips on getting rid of unnecessary resource hogs, for an editing session.
          • 2. Re: Elements 7 - Memory Errors
            When a program hangs, crashes, pre-maturely closes, etc., there is often something going on behind the scenes. Usually, there is a breadcrumb trail on what is happening.
            This ARTICLE will give you tips on how to gather clues as to what is happening, when things are messing up around your program.
            • 3. Re: Elements 7 - Memory Errors
              Though written for PrPro (PrE's big brother), the tips in the linked PrPro-Wiki have many universals to help with issues regarding an NLE.
              • 4. Re: Elements 7 - Memory Errors
                One last comment, Memory Allocation can signal that there is some program, or Process that is mis-reporting its memory usage (either RAM, or Page File), or that it is not releasing it, when Windows thinks that it has.
                It could also signal that there is a physical problem with, say a RAM chip. There are several freeware RAM testing utilities. I'd Google for those, and run one, just in case. I have not used one in decades, so have no direct experiences to help choose one from the others.
