4 Replies Latest reply on Dec 4, 2009 2:53 AM by Shivik
    Accessing xml files in Cairngorm
    Shivik Level 1
      Hello all
      I creating a simple application to access some xml data using Cairngorm. I used HTTPService and defined it inside a Services.mxml file. Now where should I put the xml file and what URL should I put in the HTTPService?
      When creating a cairngorm directory structure, there are so many directories what is root folder? Here is my directory structure....
      project
      bin
      Main.swf (I am going to run the app in AIR over here)
      libs
      src
      xml
      myxml.xml
      business
      Services.mxml (Here I defined the HTTPService)
      delegates
      MyDelegate.as (define an instance of HTTPService here)
      events
      MyEvent.as
      responders
      commands
      MyCommand.as (define the delegate here)
      views
      MyView.mxml (event is fired here)
      Main.mxml (view is defined here)
      I tried using the url "./xml/myxml.xml". This gave the "Error #2032 stream error".
      What should I do here?
      With best regards
      SHiVik
