5 Replies Latest reply on Dec 7, 2009 9:17 AM by RK...
    how to typecast string to xml Nodelist in java
    sathiyabala Level 1
      hai
         i need to convert the string to nodelist in java
      Element parentcustom = (Element)nod;
      String resultNodeValue = replaceAngleBracketsChildType(parentcustom.toString());
      NodeList parentcustomList = (NodeList)resultNodeValue;
      i have done it in above way, but i am not getting the correct answer
      i need this        resultNodeValue  to be converted to nodelist...
      can any one help me
      Thanks in Advance...
        • 1. Re: how to typecast string to xml Nodelist in java
          RK... Level 3
          Your requirement is to get "parentcustomdetails" inside  "parentruledetails" node?.
          The following code will do that,
          NodeList children = doc.getDocumentElement().getChildNodes();
          for (int i = 0; i < children.getLength(); i++) {
               Node parentRule = children.item(i);
               if (parentRule.getNodeName().equals("Parentrule")) {
                    NodeList nlParentRule = parentRule.getChildNodes();
                    for (int j = 0; j < nlParentRule.getLength(); j++) {
                         Node parentRuleDetails = nlParentRule.item(j);
                         if (parentRuleDetails.getNodeName().equals(
                                   "parentruledetails")) {
                              NodeList nlParentRuleDetails = parentRuleDetails
                                        .getChildNodes();
                              for (int k = 0; k < nlParentRuleDetails.getLength(); k++) {
                                   Node parentCustomDetails = nlParentRuleDetails
                                             .item(k);
                                   if (parentCustomDetails.getNodeName().equals(
                                             "parentcustomdetails")) {
                                        NamedNodeMap attributes = parentCustomDetails
                                                  .getAttributes();
                                        System.out.println(parentCustomDetails
                                                  .getNodeName());
                                        for (int l = 0; l < attributes.getLength(); l++) {
                                             Node attr = attributes.item(l);
                                             System.out.println("\t"
                                                       + attr.getNodeName() + " -- "
                                                       + attr.getNodeValue());
          The output of this code is,
          parentcustomdetails
               CHILD_TYPE -- Console
               CMD_CODE -- 37135
               CMD_NAME -- login authentication [string]
               CMD_OPTION -- login authentication
               COLUMN_INDEX -- 0
               CONDN_OPER -- exists
               CONDN_VALUE -- True
               PARENT_RULE_CODE -- PR630
               RULE_TYPE_FLAG -- Customrule
          parentcustomdetails
               CMD_CODE -- 37135
               CMD_OPTION -- string
               COLUMN_INDEX -- 1
               CONDN_OPER -- equalsto
               CONDN_VALUE -- AAAAAAAAA
          • 2. Re: how to typecast string to xml Nodelist in java
            sathiyabala Level 1
            sorry again
            the thing u gave is right but, if i get the nodename and nodevalue .. i cant set that value.
            i need to get set the attribute and then oly i can save it in db
            can u say me that pl
            • 3. Re: how to typecast string to xml Nodelist in java
              sathiyabala Level 1
              sorry again
              File file =
              new File(pFilePath);
              DocumentBuilderFactory dbf = DocumentBuilderFactory.newInstance();
              DocumentBuilder db = dbf.newDocumentBuilder();
              Document doc = db.parse(file);
              System.
              out.println(":nlParentRule::::::::INSIDE PARENTRULE::::::::::::::");
              if (parentRuleDetails.getNodeName().equals("parentruledetails")) {
              System.
              out.println(":nlParentRule::::::::INSIDE PARENTRULEDETAILS::::::::::::::");
              NodeList nlParentRuleDetails = parentRuleDetails.getChildNodes();
              Node parentCustomDetails = nlParentRuleDetails.item(k);
              System.
              out.println(":nlParentRuleDetails.item(k):::::::::::::::"+nlParentRuleDetails.item(k));
              if (parentCustomDetails.getNodeName().equals("parentcustomdetails")) {
              NamedNodeMap attributes = parentCustomDetails.getAttributes();
              System.
              out.println(":::::::::::::::::::::::"+parentCustomDetails.getNodeName());
              for (int l = 0; l < attributes.getLength(); l++){
              Node parentcustomcommand = attributes.item(l);
              System.
              out.println("::::::::attributes.item(l):::::::::::::::"+attributes.item(l));
              lParentExportForm.setParentcustomchildtype(parentcustomcommand.getAttribute(
              "CHILD_TYPE"));
              lParentExportForm.setParentfiltercmdcode(lParentImportDAO.findCommandCode(lParentExportDel egate.reverseCommandOperator(parentcustomcommand.getAttribute(
              "CMD_NAME")),pConnection));
              if(lParentExportForm.getParentfiltercmdcode()== null || lParentExportForm.getParentfiltercmdcode()==""){
              lParentExportForm.setParentfiltercmdcode(lParentImportDAO.findCommandCode(parentcustomcomm and.getAttribute(
              "CMD_NAME"),pConnection));
              lParentExportForm.setParentfiltercmdname(parentcustomcommand.getAttribute(
              "CMD_NAME"));
              lParentExportForm.setParentfiltercmdoption(parentcustomcommand.getAttribute(
              "CMD_OPTION"));
              lParentExportForm.setParentfiltercustomcolumnindex(parentcustomcommand.getAttribute(
              "COLUMN_INDEX"));
              lParentExportForm.setParentfilterconditionoptr(parentcustomcommand.getAttribute(
              "CONDN_OPER"));
              lParentExportForm.setParentfilterconditionval(parentcustomcommand.getAttribute(
              "CONDN_VALUE"));
              lParentExportForm.setParentfiltertypeflag(parentcustomcommand.getAttribute(
              "RULE_TYPE_FLAG"));
              lParentImportDAO.insertParentCustomDetails(lParentExportForm,parentcode, pConnection);
              • 4. Re: how to typecast string to xml Nodelist in java
                sathiyabala Level 1
                sorry again
                "CHILD_TYPE"));
                "CMD_NAME"));
                "CMD_OPTION"));
                "COLUMN_INDEX"));
                "CONDN_OPER"));
                "CONDN_VALUE"));
                "RULE_TYPE_FLAG"));
                lParentExportForm.setParentfiltercustomcolumnindex(parentcustomcommand.getAttrib ute(
                lParentExportForm.setParentfiltercmdcode(lParentImportDAO.findCommandCode(parent customcommand.getAttribute(
                lParentExportForm.setParentfiltercmdcode(lParentImportDAO.findCommandCode(lParen tExportDelegate.reverseCommandOperator(parentcustomcommand.getAttribute(
                System.
                System.
                System.
                System.
                System.
                File file =
                • 5. Re: how to typecast string to xml Nodelist in java
                  RK... Level 3
                  What does this mean? I didn't get you.
