0 Replies Latest reply on Dec 4, 2009 5:23 AM by Carol L. Frampton
    [svn:fx-trunk] 12528: TLF Build 565.
    Carol L. Frampton Level 2
      Revision: 12528
      Revision: 12528
      Author:   cframpto@adobe.com
      Date:     2009-12-04 05:23:14 -0800 (Fri, 04 Dec 2009)
      Log Message:
      TLF Build 565.
      Build 565
      • Fix 2498059 Selection highlighting and caret can dissapear when switching EditingMode in TCM
      • Fix 2496825 Scolling lines via arrow keys in text which is not using Up leading, causes assert.
      • Fix 2496529 Error happens when running TextContainerManagerTest.aliceTCMTest on Argo StandAlone for Mac.
      Build 564
      • Fix 2497046. Change to core build file to provide ASDocs in the OpenSource folder instead of compiled into the textLayout.SWC. Also added the manifest file to the textLayout.SWC so that mxml code hinting in Flash Builder can work.
      • Fix 2496983 HTML TextConverter converts HREF property to lower-case characters
      • Improvements to Fix 2491878 Page Down and Page Up don't work properly in the linked containers
      Build 563
      • Fix 2496260 HTML Import Performance Improvements
      • Fix 2497051 Rename GlobalSettings.getResourceStringFunction to resourceStringFunction
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24493
          http://bugs.adobe.com/jira/browse/SDK-24468
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.compos e.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.edit.x ml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.format s.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.operat ions.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextLineRecyc ler.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/BaseTextLa youtImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/HtmlImport er.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/TextLayout Importer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/debug/Debugging.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextLineFacto ryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextLayoutFo rmat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor mat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/utils/NavigationUtil. as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.565.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.562.swf
