8 Replies Latest reply on Dec 4, 2009 8:58 AM by Gregory Lafrance
    How do I get rid of this error?
    Jerry62712 Level 1
      In this code:
              private function processSearchRecord():void
                  var psrSODC:String = dgSearchResults.selectedItem.colSODC as String;
                  var psrLastName:String = dgSearchResults.selectedItem.colLastName as String;
                  var psrFirstName:String = dgSearchResults.selectedItem.colFirstName as String;
                  var psrMHDDID:String = dgSearchResults.selectedItem.colMHDDID as String;
                  var psrRIN:String = dgSearchResults.selectedItem.colRIN as String;
                  var psrSSN:String = dgSearchResults.selectedItem.colSSN as String;
                  if (psrSODC != null && psrSODC.length > 0)
      ====>       XMLRecord.RecProcess = dmSearch.RecProcess(SODC == psrSODC);
      at the indicated line I get this error:
      1176: Comparison between a value with static type mx.controls:TextInput and a possibly
      unrelated type String.
      The XMLRecord is defined as:
              [Bindable] private var XMLRecord:XML;
      and the XML tag (is this the same as the above?):
      <mx:XML id="dmSearch">
          <data>
              <SearchResults>
                  <result>
      xxx
                 </result>
              </SearchResults>
              <SearchCriteria>
      xxx
             </SearchCriteria>
              <RecProcess>
                  <ADDRESS />
                  <AGE />
                  <AGENCYCONTACTNUMBER />
      I originally didn't have the "XMLRecord.RecProces" and just had "XMLRecord" which also gave this error:
      TIA,
      Jerry
        • 1. Re: How do I get rid of this error?
          Gregory Lafrance Level 6
          I suspect SODC is a TextInput, thus you need SODC.text
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance
          www.ChikaraDev.com
          Flex Development and Support Services
          • 2. Re: How do I get rid of this error?
            Jerry62712 Level 1
            That's why I like talking to you.  You get things moving.  Yes, some of the fields are text (perhaps all - some are arrays).
            When I changed it to:
                            XMLRecord = dmResults(SODC.text == psrSODC);
            I get a new error:
            1180: Call to a possibly undefined method dmResults.
            "dmResults" is an id for an XML tag.  The goal is to filter the grid to one record.  I don't know how the magic of the grid and the XML item are connected.
            • 3. Re: How do I get rid of this error?
              Jerry62712 Level 1
              I changed to this:
                      [Bindable] private var XMLRecord:XML(dmResults);
              with the hope that XMLRecord would now look like the XML id="dmResults.  It gives me this error:
              Multiple markers at this line: -1086: Syntax error: expecting semicolon before colon. -1 changed
              line
              dmResults looks like this:
              <mx:XML id="dmResults">
                  <data>
                      <ADDRESS />
                      <AGE />
                      <AGENCYNAME />
              xxx
              Changing it to the above removed the error on this line:
              (modified per your suggestion to include the ".text")
              • 4. Re: How do I get rid of this error?
                Thanks for the nice words. I'm doing Flex consulting full-time now, so please tell your friends.
                dmSearch.RecProcess(SODC.text == psrSODC);
                Greg Lafrance
                www.ChikaraDev.com
                • 5. Re: How do I get rid of this error?
                  Jerry62712 Level 1
                  Good for you.  I use to do consulting in Paradox, but now that I'm older I just want a stable job (and medical)!
                  That did clear up the error on that line.  But I still have the error on the other line.
                  where I'm trying to associate XMLRecord with the XML tag with the id of dmResults.  It complains:
                  line
                  Where are you located?  I'm in Springfield, Illinois as a state worker.
                  • 6. Re: How do I get rid of this error?
                    danny_run Level 1
                    the variable definition format is:
                    [Bindable]
                    private var your_var:VarType=VarType(value_you_want_to_cast_to_VarType);
                    In your case:
                    [Bindable]
                    private var XMLRecord:XML=XML(dmResults);
                    • 7. Re: How do I get rid of this error?
                      Jerry62712 Level 1
                      Again you pointed me in the right direction.  Here is what I ended up with:
                              [Bindable] private var XMLRecord:XML= dmResults;
                      I get an error back here now:
                                      XMLRecord = dmResults(LASTNAME.text == psrLastName);
                      What this is suppose to do is filter the datagrid (how that gets to the dmResults isn't clear to me) so one record gets to the XMLRecord.
                      • 8. Re: How do I get rid of this error?
                        What's the error, and try this:
                        XMLRecord = dmResults.(LASTNAME.text == psrLastName);
                        or this:
                        XMLRecord = dmResults.@(LASTNAME.text == psrLastName);
                        I'm located in Cupertino, CA. One thing I offer is Flex support $80/hour, billable in 15 minute increments. So if you have a question and don't want to go through the forum and I answer it quickly, 15 minutes minimum charge. For more involved questions, bug fixing, and development, charged for time spent.
                        It is a model that works well for some people I'm working with. It allows them to tae on projects they otherwise would need to pass on.
