0 Replies Latest reply on Dec 4, 2009 5:42 AM by CHAVALASD
    Urgent help required to make variableRowHeight & rowCount work hand in hand for a Datagrid
    CHAVALASD
      HI,
      I am using variableRowHeight property on a datagrid to wrap the text and this works perfectly.
      At the same time, I have to assign rowCount dynamically. My logic for caluculating rowCount is
      rowcount = sampleData.length > 5 ? 5:sampleData.length; where sampleData is my ArrayCollection. The caluculation happens correctly.
      The issue here is rows of the datagrid do not show correctly.
      From the post http://forums.adobe.com/message/2350643#2350643 I understood that both variableRowHeight & rowCount do not work hand in hand.
      So, I tried removing variableRowHeight and it works fine. The solution says using measureHeightOfItems and viewMetrics to calculate the height may solve the issue. I did not understand it very clearly.
      Can anyone let me know the solution with example.
      Thnaks
      Code
      <?xml version="1.0"?>
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" initialize="init()"
      xmlns:itemren="
      com.itemren.*">
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import com.vo.HeaderVO;
      import com.vo.DataVO;
      import mx.utils.ObjectUtil;
      import mx.collections.IViewCursor;
      import mx.controls.Alert;
      import mx.collections.ArrayCollection;
      Bindable]
      public static var sampleData:ArrayCollection = new ArrayCollection ();
      Bindable]
      public var rowcount:int;
      public function init():void {
      sampleData.addItem( { AssetNo :
      "234567890", AssetName : "Asset Name 1", Amount : "10000.02" } );
      "234567891", AssetName : "Asset Name 2", Amount :"2.04" } );
      "234567892", AssetName : "Asset Name 3", Amount : "4578.00" } );
      "234567893", AssetName : "Asset Name 4", Amount : "384.00" } );
      "234567894", AssetName : "Asset Name 5", Amount : "21454.20" } );
      trace ("sampleData.length ========= "+sampleData.length);
      trace("count is ==== "+rowcount);
      dg.rowCount=rowcount;
      trace("dg.rowCount is === "+ObjectUtil.toString(dg.rowCount));
      dg.dataProvider=sampleData;
      </mx:Script>
      <mx:Panel title="POC for dynamic rowCount of datagrid" height="100%" width="100%"
      paddingTop="
      10" paddingLeft="10" paddingRight="10">
      <mx:DataGrid id="dg" width="50%" wordWrap="true"
      variableRowHeight="
      true">
      <mx:columns>
      <mx:DataGridColumn dataField="AssetNo" headerText="Asset No" paddingLeft="20" />
      <mx:DataGridColumn dataField="AssetName" headerText="Asset Name" paddingLeft="20"/>
      <mx:DataGridColumn dataField="Amount" headerText="Amount" paddingLeft="20"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Panel>
      </mx:Application>
