0 Replies Latest reply on Dec 4, 2009 5:54 AM by CHAVALASD
    Urgent!! Custom LinkButton (Used as itemRenderer for datagrid) text wrap issue
    CHAVALASD
      I have a custom component MultiLineLinkButton which extends LinkButton. I am using this custom component as an itemrenderer for a column in datagrid.
      When i try to resize this column in the datagrid the text is not getting wrapped. I have variableRowHeight on my datagrid for wrapping other normal columns which works fine.
      I also tried setting the height by getting the instance of MultiLineLinkButton on columnStretch of datagrid which did not work.
      Could you please suggest me how I can wrap the text in this custom component and in general for any other itemrenderers in a datagrid.
      Hope i will get a solution soon,
      Code
      public
      class MultiLineLinkButton extends LinkButton
      Bindable]
      public var buttonWidth:int = 88;
      public function MultiLineLinkButton()
      super();
      override protected function createChildren():void {
      trace("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!MultiLineLinkButton-createChildren!!!!!!!!!!!!!!!!!");
      super.createChildren();
      if (textField){
      textField.wordWrap =
      true;
      textField.multiline =
      true;
      override public function measureText(s:String):TextLineMetrics {
      trace("@@@@@@@@@@@@@@@@@@@@@@@!MultiLineLinkButton-measureText@@@@@@@@@@@@@@@@@@@@@@@@@@@ = "+s);
      textField.text = s;
      //textField.width = buttonWidth;
      var lineMetrics:TextLineMetrics = textField.getLineMetrics(0);
      lineMetrics.width = textField.textWidth;
      lineMetrics.height = textField.textHeight;
      return lineMetrics;
