1 Reply Latest reply on Dec 5, 2009 5:29 PM by Skullmaker
    Suppress dialog box for font not found
    Medaloo
      using VB I open AI and load ai files and send commands to save them in several image types, there are times that a dialog box stating Font not found with OK Cancel button appears. I need to suppress this dialog so my program does not hang. any advice will be highly appreciated. Thanks
      Medallo
        • 1. Re: Suppress dialog box for font not found
          Skullmaker Level 3
          You cannot suppress this warning. Every time you open a document Illustrator will let you know that you do not have the font on your computer or is not active.
          The reason of this warning is because the layout may change, words or symbols could disappeared, etc. This warning cannot be ignore. If you do not have the font, you have to assigned a new font and make sure that the artwork is correct and nothing is missing.
          I hope this helps!
