• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RH8 + WinXP - whnjs.htm listed in broken links - crash
Guest
Dec 04, 2009 Dec 04, 2009
RH8 + WinXP.
I am working on the Help topics for a web-based application.  I inherited this project from another contractor.  The other contractor used RH6 to create about 300 topics, each topic in a dot htm file.  He also created an extensive TOC.
Each htm file is named according to a file-naming system set up by the original contractor.  The system uses upper- and lower-case letters and underscores.  For example:
help_quickstart_mainmenu_Reports_howtowriteareport.htm
help_quickstart_mainmenu_Reports_howtoeditareport.htm
etc.
I started with RH7 and recently upgraded to RH8.  At some point, the "all lower case for Unix" function was activated and all Help topics were renamed.  I was able to restore all of the topic files from version control but all of the files generated by RH were also affected and the table of contents and the appearance of the Help display was affected.  I have been working to restore the table of contents and just today noticed that the whnjs.htm file was located in the Broken Links list.  When I right-clicked on the file name in the list, RH8 instantly crashed and the interface disappeared off of my monitor. I was able to restart RH8, as usual, by clicking the icon on my toolbar and I don't see any other problems caused by the crash but I still see the whnjs file in Broken Links and the TOC is still a mess - no book or page icons, frameset is a different color, etc.
What can you tell me about the whnjs file and what should I do now?  Thanks.
Views
447
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Hi there
Your post would seem to indicate you have managed to pull generated output files into your source and replace the source files with them. Ouch!
If you have a backup, definitely time to restore.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
Guest
Thanks, Captiv8tor.  You've confirmed my worst fears about "contaminating" our version control files.  I am up against a release deadline and I don't feel I have time to pull 300 topic files out of subversion and do a new build of Help.  Do you have any other advice?  Can I delete the whnjs and whskin_blank files from the lists in RH?  Thanks.
Votes
Translate
Translate
Report
Report
Community Expert ,
Dec 06, 2009 Dec 06, 2009
LATEST
Output files in the source are not going to generate new help without a big cleanup as described on Rick's site. There's a lot more to it than just deleting those files.
I suspect pulling an old version will be quicker.
Follow me @petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
