3 Replies Latest reply on Dec 8, 2009 11:27 AM by Shongrunden
    Setting a stroke style on a Skinnable container?
    Handycam Level 1
      I have a SkinnablerContainer skin that I made using the "new skin from copy".  I've got it working with the fill properties included, but I'd also like to add some control for stroke.  I did this, but the component instance says "Cannot resolve attribute 'borderWeight' for component type spark.components.SkinnableContainer".
      <fx:Script fb:purpose="styling">
          <![CDATA[
               *  @private
              override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number) : void
                  bgFill.color = getStyle("backgroundColor");
                  bgFill.alpha = getStyle("backgroundAlpha");
                     bgStroke.color = getStyle("borderColor");
                     bgStroke.weight = getStyle("borderWeight");
                  super.updateDisplayList(unscaledWidth, unscaledHeight);
      </fx:Script>
      <s:states>
          <s:State name="normal" />
          <s:State name="disabled" />
      </s:states>
      <s:Rect left="0" right="0" top="0" bottom="0" radiusX="12">
          <s:fill>
              <s:SolidColor id="bgFill"/>
          </s:fill>
           <s:stroke>
                <s:SolidColorStroke id="bgStroke"/>
           </s:stroke>
      </s:Rect>
        • 1. Re: Setting a stroke style on a Skinnable container?
          Gaurav J Adobe Employee
          The following:
          getStyle(borderColor);
          will call getStyle method on SkinnableContainer. But SkinnableContainer does not define borderColor as a style which is why you are getting the error.
          It does define backgroundColor, which is why
          getStyle(backgroundColor);
          worked.
          You can do, somthing like
          bgStroke.color = #FF0000;
          or call getStyle for a style that exists on SkinnableContainer..
          Hope that helps.
          Gaurav Jain
          Flex SDK Team
          • 2. Re: Setting a stroke style on a Skinnable container?
            Handycam Level 1
            OK, so what component could I use that supports a borderColor?
            Also, in the past I have "made up" my own styles:
            <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                      minWidth="21" minHeight="21"
                      alpha.disabled="0.5">
                 <fx:Metadata>
                      [HostComponent("spark.components.Button")]
                 </fx:Metadata>
                 <fx:Script>
                      [Bindable] private var tColor:uint;
                      [Bindable] private var tColorOver:uint;
                      [Bindable] private var tColorDown:uint;
                      [Bindable] private var tColorDisabled:uint = 0xCCCCCC;
                      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                           bgcolor.color = getStyle("backgroundColor");
                           bgcolorover.color = getStyle("backgroundOverColor");
                           bgcolordown.color = getStyle("backgroundDownColor");
                           tColor = getStyle("color");
                           tColorOver = getStyle("colorOver");
                           tColorDown = getStyle("colorDown");
                 </fx:Script>
                 <s:Rect top="0" left="0" right="0" bottom="0" radiusX="6" radiusY="6">
                      <s:filters>
                           <s:BevelFilter strength=".3" distance="2" blurX="4" blurY="4"/>
                      </s:filters>
                      <s:filters.down>
                           <s:BevelFilter strength=".3" distance="-2" blurX="4" blurY="4"/>
                      </s:filters.down>
                      <s:fill>
                           <s:SolidColor id="bgcolor" />
                      </s:fill>
                      <s:fill.over>
                           <s:SolidColor id="bgcolorover" />
                      </s:fill.over>
                      <s:fill.down>
                           <s:SolidColor id="bgcolordown" />
                      </s:fill.down>
                 </s:Rect>
            Why does it work here?  Or does this only support css and not mxml?
            • 3. Re: Setting a stroke style on a Skinnable container?
              Shongrunden Adobe Employee
              Try the BorderContainer component (used to be Border)
