2 Replies Latest reply on Dec 4, 2009 4:29 PM by katmac75
    Using a script to fill out a template
    katmac75
      I'm working on a script to fill in an InDesign template I've created. The template consists of 8 text frames, each with a logo placed as an in-line graphic. What I need the script to do is to add text it has gathered after the in lines after the logos. The text frames will all be identical, so I've been trying variations of:
      tell application "Adobe InDesign CS3"
          tell active document
              tell active page
                  tell every text frame
                      set paragraph 2 to label_info
                  end tell
              end tell
          end tell
      end tell
      It seems like the problem is in getting InDesign to even recognize the text frames so I can work with them. Eventually, I will also need to set paragraph styles and export a PDF of the document, but I'm just trying to figure this out one step at a time for now.
