1 Reply Latest reply on Dec 4, 2009 2:21 PM by Flex harUI
    Finding the width of a component
    SiHoop Level 1
      I'm using the file below to load a series of images into a container named containerSprite. The size of each image will vary and I want to be able to calculate the width of the container so I can place navigation buttons relative to the position of containerSprite. My code does not work when the first image is loaded-- when I use trace("WIDTH="+containerSprite.width) I get 0 the first time through.
      How or where should I set up an event listener that will fire only when the image has finished loading.
      Thanks for helping me think through this process.
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" applicationComplete="init()" >
          <mx:Script>
              <![CDATA[
                  import mvc.SlideShowTextView;
                  import flash.display.*;
                  import flash.events.*;
                  import flash.net.URLRequest;
                  import mvc.SlideShowModel;
                  import mvc.SlideShowView;
                  import mvc.Model;
                  import mvc.View;
                  import flash.text.TextField;
                  private var slideModel:SlideShowModel;
                  private var slideView:SlideShowView;
                  private var textView:SlideShowTextView;
                  private var req:URLRequest=new URLRequest("data.xml");
                  private var containerSprite:Sprite;
                  private var s:Shape;
                  private var titleText:TextField
                  private var numbersText:TextField
                  private function init():void{
                      titleText=new TextField;
                      numbersText=new TextField;
                      containerSprite=new Sprite;
                      containerSprite.addEventListener(MouseEvent.CLICK, containerClicked)
                      s=new Shape;
                      containerSprite.addChild(s)
                      holder.addChild(containerSprite)
                      holder.addChild(titleText)
                      holder.addChild(numbersText)
                      slideView=new SlideShowView(containerSprite);
                      slideModel=new SlideShowModel;
                      textView=new SlideShowTextView(titleText,numbersText);
                      slideView.model=slideModel;
                      textView.model=slideModel;
                      slideModel.addEventListener(Model.MODEL_CHANGE, dataChanged);
                      slideModel.load(req);
                      titleText.x=0//containerSprite.x
                      titleText.y=500//containerSprite.y+containerSprite.height+10
                      numbersText.x=500//containerSprite.x+containerSprite.width-100
                      numbersText.y=titleText.y
                  private function dataChanged(event:Event):void{
                  private function containerClicked(event:MouseEvent):void{
                      slideModel.setCurrentIndex(slideModel.currentIndex+1)
          </mx:Script>
      <mx:UIComponent id="holder"  horizontalCenter="-250" />
      </mx:Application>
