0 Replies Latest reply on Dec 4, 2009 2:51 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12557: Fix http://bugs.adobe.com/jira/browse/ SDK-24324 Dragging an item from a DataGrid that is in an application loaded into SWFLoader causes a RTE
      Revision: 12557
      Revision: 12557
      Author:   egeorgie@adobe.com
      Date:     2009-12-04 14:51:10 -0800 (Fri, 04 Dec 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-24324 Dragging an item from a DataGrid that is in an application loaded into SWFLoader causes a RTE
      Problem: The DragProxy and DragManagerImpl/NativeDragManagerImpl are looking up the styles from the top level app.
      Fix: Make them look up the styles from the module of the drag initiator.
      Credits go to Darrell for this fix!
      QE notes: None
      Doc notes: None
      Bugs: SDK-24324
      Reviewer: Darrell
      Tests run: checkintests, mustella cyclone
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/NativeDragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
