Revision: 12545
Revision: 12545
Author: rfrishbe@adobe.com
Date: 2009-12-04 11:31:50 -0800 (Fri, 04 Dec 2009)
Log Message:
flash-integration.swc is no longer built in to utilities.swc. It is now it's own standalone swc that needs to be packaged up as part of the SDK. This is so Flash Builder can find the source code for the swc.
I'm also making some other changes for OSMF. Jim is going to make the rest of them to support fat-swcs.
QE notes: -
Doc notes: -
Bugs: SDK-24471
Reviewer: Pete reviewed some of this
Tests run: checkintests
Is noteworthy for integration: Yes
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24471
Modified Paths:
flex/sdk/trunk/build.xml
flex/sdk/trunk/frameworks/build.xml
flex/sdk/trunk/frameworks/flash-integration/FlexComponentKit.mxp
flex/sdk/trunk/frameworks/projects/flash-integration/FlexComponentKit.mxi
flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
flex/sdk/trunk/frameworks/projects/osmf/build.xml
flex/sdk/trunk/frameworks/projects/osmf/src/OSMFClasses.as
flex/sdk/trunk/frameworks/projects/utilities/build.xml
Added Paths:
flex/sdk/trunk/frameworks/projects/osmf/src/OSMFDocClasses.as
