0 Replies Latest reply on Dec 4, 2009 3:10 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12558: Fix http://bugs.adobe.com/jira/browse/ SDK-24457 A Path does not get filled in sometimes if the Path's lines cross
    Evtim Georgiev (Adobe) Level 2
      Revision: 12558
      Revision: 12558
      Author:   egeorgie@adobe.com
      Date:     2009-12-04 15:10:43 -0800 (Fri, 04 Dec 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-24457 A Path does not get filled in sometimes if the Path's lines cross
      Problem: There's a bug in DAPI2 that a single unconnected quadratic segment doesn't get filled.
      Fix: Detect the case and draw a zero-length line segment to force correct fill.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24457
      Reviewer: Deepa
      Tests run: checkintests, mustella spark/primitives
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
