Revision: 12568
Revision: 12568
Author: gruehle@adobe.com
Date: 2009-12-04 16:33:54 -0800 (Fri, 04 Dec 2009)
Log Message:
Fix the theme attribute for cornerRadius metadata on mx components. This required moving the metadata out of BorderStyles.as and into each file that includes BorderStyle.as
QE notes: -
Doc notes: -
Bugs: SDK-24437
Reviewer: Kevin
Tests run: checkintests
Is noteworthy for integration: no
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24437
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NumericStepper.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ToolTip.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/VideoDisplay.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ScrollControlBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/metadata/BorderStyles.as
