4 Replies Latest reply on Dec 6, 2009 7:19 AM by inquestflash
    masking an obgject with cc snow effect!!!(help)
    inquestflash Level 1
      hello to all!!
      im stuck on a project of mine and surely would like  some one to help me out plssssss!
      i want to mask into a crystal ball cc snow from the after efffects presets which u can find,i draw out a circle with  the pen tool but the snow appears on all the screen not just into the crystal ball.how can i get the snow fall just in the crystal ball??!?!??!
      best regards.
        • 1. Re: masking an obgject with cc snow effect!!!(help)
          Adolfo Rozenfeld Adobe Employee
          Inquestflash: You would have to Pre-Compose the layer with CC Snow, before applying the Mask to the resulting Pre-Comp.
          So, it would  be as follows:
          1. Apply the CC Snow effect to the layer you want.
          2. With just that layer selected, go to Layer > Pre-Compose (Command + Shift + C on Mac, Control + **** + C on Windows).
          3. In the Pre-Compose dialog, make sure you select the second option ("Move all attributes into the new Composition").
          4. Draw the circular Mask on the resulting Pre-Comp.
          The reason why we're doing this is processing order: If you go right now and twirl open the layer with CC Snow in the timeline, you'll see property groups in this order: Masks,  Effects, Transform. This means that, for each frame, AE  applies masks first, then effects and then transform properties. The Mask can't restrict CC Snow because it's applied before the effect. By Pre-Composing, you're forcing everything inside the Pre-Comp to be processed before everything applied outside (For example, a Mask you add to the Pre-Comp).
          • 2. Re: masking an obgject with cc snow effect!!!(help)
            dear Adolfo Rozenfeld may u have a great x-mass and a happy new year!ur a
            life savour dude thanx a million!!!
            best regards.
            2009/12/5 Adolfo Rozenfeld <forums@adobe.com>
            So, it would  follows:
            Pre-Comp).
            • 3. Re: masking an obgject with cc snow effect!!!(help)
              Evidently, I made a mistake when typing the name of the shift key
              Thanks for the wishes. Same to you.
              • 4. Re: masking an obgject with cc snow effect!!!(help)
                hello adoldo!
                one more question if u dont mind,all is working well with the masking of the
                cc snow,but!!!since im making a crystal ball with a x-mass tree in it,id
                like for the cc snow mask to be transperant with no background,because its
                overlaping the x-mass tree.so is it possible for the cc snow to be masked in
                a circle but with no background?so image your making a snow crystal globe:
                http://www.oneter.com/wp-content/uploads/2008/12/005_b.jpg<http://www.oneter.com/wp-content/uploads/2008/12/005_b.jpg>
                how wold to make the snow not over lapping the x-mass tree.
                thank you again.
                2009/12/6 Adolfo Rozenfeld <forums@adobe.com>
