1 Reply Latest reply on Jun 13, 2008 11:14 AM by Damon Edwards
    ComboBox not working correctly
      Hi there,
      I am developing a small Flash (AS2) application, using Flash CS3, and have run into a problem with the ComboBox componet.
      I am loading another movie into the main movie with the following code:
      var container = _level0.createEmptyMovieClip("ui_slider", _level0.getNextHighestDepth());
      trace("On last frame");
      ui_slider._x = 60;
      ui_slider._y = -382
      everything works fine, but none of the comboBoxes are working. I can see the first item that can be selected, but the pull-down selection is not working. Nothing happens when I click it.
      the ui-sliderv2.swf movie works as expected when run on its own.
      Here are the links to the SWF.
      The menu SWF on it's own:
      Any suggestions?
