3 Replies Latest reply on Dec 6, 2009 1:27 PM by Lost In My Mind
    Feather Mask
    Lost In My Mind Level 1
      'By default, the feather width straddles the mask edge, half inside and half outside.'
      Is there a way to change the default so that the feathering goes from the edge of the mask out only, without going in as well? Thanks. Cin
        • 1. Re: Feather Mask
          Todd_Kopriva Level 8
          One approach is to expand the mask a little.
          • 2. Re: Feather Mask
            No, unfortunately AE's feathering is always two sided. The only way to directly manipulate masks in that manner would be to use Revision FX' PV Feather plug-in. You can, however, quite easily fake it using otehr means. E.g. you could put your mask stuff on top of your footage and use it as a matte. By applying the Outer Glow layer style, it would then only expand outside the mask contours. the only potential caveat here - once more - is, that you may need to pre-compose since layer styles are applied as the last step and may not correctly contribute to the layer's pixels with certain blending modes or when layers are used with 3D....
            • 3. Re: Feather Mask
              Thank you Todd. I had read that link before, and that was the method I have been using, but it doesn't quiet give the results I was looking for. Thank you Mylenium for the nice work around. I appreciate your help and expertise as always. Cin
